Fixing side mirrors that keep adjusting themselves
10-25-2014, 08:03 PM | #1 |
71
Rep 272
My drivers side mirror seem to move by itself and was in a different spot each time i got into the car. Really sick on having to adjust it back to the right spot all the time.... Found a DIY on the net so had a go and problem fixed....
Thought I'd rewrite the fix cause I cant find the link to the original DIY hope this helps.... Problem: Drivers side mirror keeps moving from where you set it Cause: Corrosion on the mirror motor connector pins Fix: Remove mirror glass, motor, clean pins Time: Approx 15 mins Difficulty: 2/10 Notes: The drivers side mirror adjusts automatically to the last position in the seat memory/key fob (regardless of if you have auto adjust on or off in idrive) Corrosion on the mirror motor pins can cause the mirror to self adjust to the wrong position The passenger side mirror does not self adjust. Some people have reported that their passenger side mirror will point down to the ground. This is normal. Its a feature to help see the curb when reversing. The feature is activated by having your mirror switch in the right position. If you want to turn this function off, keep your mirror switch in the left position The following fix is for the drivers side mirror problem Last edited by Drill; 10-26-2014 at 01:29 AM.. |
10-25-2014, 08:09 PM | #2 |
71
Rep 272
Step 1 - Removing mirror glass
The glass mirror is glued to a plastic backing plate that clips onto the mirror motor inside the mirror casing
It is pops off easily with a bit of light prying with a screw driver inserted behind the mirrors plastic backing plate Use light pressure, working around the mirror until it pops off Careful not to drop it !! |
BSG33530.50 |
10-25-2014, 08:13 PM | #3 |
71
Rep 272
Step 2 - Disconnecting the mirror
Depending on the type of mirror you have (heated, folding etc) there will be a number of wires to unplug before you can free the mirror
Mine is the basic version so there are only two small wires to disconnect Unplug them and put the mirror somewhere safe Last edited by Drill; 10-26-2014 at 01:30 AM.. |
BSG33530.50 |
10-25-2014, 08:18 PM | #4 |
71
Rep 272
Step 3 - Removing the mirror motor
The mirror motor is secured in place with a single torx screw
Remove the screw and put it somewhere safe The mirror motor is now held in place by a connector behind the motor, simply pull the motor towards you and it will pop off (feels like it is still screwed in but it is not, just takes a little effort) Last edited by Drill; 10-25-2014 at 08:43 PM.. |
BSG33530.50 |
10-25-2014, 08:21 PM | #5 |
71
Rep 272
Step 4 - Exposing the corroded connector pins
With the mirror motor out, turn it over and you will see the connector pins that need cleaning.
To get access to the pins, remove the mirror motor back cover. Simply pull the cover at the 3 tabs and it will pop off easily Last edited by Drill; 10-25-2014 at 08:37 PM.. |
BSG33530.50 |
10-25-2014, 08:24 PM | #6 |
71
Rep 272
Step 5 - Cleaning the corroded connector pins
Using a emery board or small nail file, lightly sand each of the pins to remove any corrosion. Take care not to bend or break any of the pins, don't go crazy, a light sand is all that is needed!!!
BSG33530.50 |
10-25-2014, 08:34 PM | #7 |
71
Rep 272
Step 6 - Reassembly and testing
Reverse the process to reassemble:
* Take care to align the corrector pins and the blue connector when plugging back in the mirror motor. * Don't forget to plug in the wires onto the right connections before refitting the mirror * Push the mirror in the middle (not the sides) when refitting the mirror to the mirror motor To test, get in the car and insert key fob without starting car Adjust the mirror using the controls to make sure everything in connected properly Remove the key fob from the ignition and without getting out of the car, lock and unlock the car with the key fob. The mirror should move to its set position. Test it out by adjusting the mirror to another position and seeing if it goes back to the same position when locking/unlocking the car If everything is working, adjust the mirror to your desired position and store the new setting in the seat memory before removing the key fob Key and seat should now be programmed and the mirror should reset correctly each time you open the car Last edited by Drill; 10-25-2014 at 08:44 PM.. |
BSG33530.50 |
10-26-2014, 01:38 AM | #8 |
59
Rep 610
nice! I'll try this out, I was starting to think it was weird how the mirror kept moving, not by much but it still was moving, and after having s horror movie marathon, not the best ://
10-26-2014, 01:48 AM | #9 |
71
Rep 272
10-27-2014, 04:48 PM | #10 |
96
Rep 1,031
Drives: 335 E92 DCT
Nice DIY
10-28-2014, 10:20 PM | #12 |
11
Rep 344
Thankyou so much. The original DIY that I printed out seemed like way too much hassle for me to tackle myself. This seems doable
Current: 2008 E90 335iA Sparkling Graphite Metallic Past: 2009 E90 LCI 323iA Black Sapphire Metallic, 2005 E46 325iA Black Sapphire Metallic, 1992 E34 535iA Glacier Blue BMW Driver's Club of South Australia member |
10-29-2014, 02:23 AM | #13 |
71
Rep 272
11-16-2014, 06:52 PM | #14 |
9
Rep 109
I'm having the same issue with my 2008 335i coupe. Driver's side mirror re-sets almost every time the car power cycles.
I'll try your method. I heard that a bad footwell controller could be the cause but I'd rather that not be the case! Greg Houston TX |
01-11-2015, 06:33 AM | #15 |
Rep 37
Anyone having problems with the passenger side?
I have the mirror move down when in reverse but then when it readjusts back up it is all over the place. Do you think this could be the same fix for the passenger side? |
01-11-2015, 08:01 AM | #16 | |
4553
Rep 11,908
Give it a go and let us know if it works |
01-11-2015, 09:22 AM | #17 |
56
Rep 936
Lol. Thats actually a feature used to help you park so you dont gutter your wheels. The mirror points downways to lookk directly at the kerb. Also helps in carparks so that you can see the markings on the floor. If you dont like this feature on the master window switches theres a sliding knob that you slide to the right which will deactivate the function.
01-11-2015, 08:59 PM | #18 |
7
Rep 54
01-11-2015, 10:30 PM | #20 |
56
Rep 936
01-12-2015, 04:44 AM | #21 |
4553
Rep 11,908
4th para in the DIY talks about the passenger mirror feature
I took from the post that the mirror was going crazy after returning from gutter view mode |
01-12-2015, 06:11 AM | #22 | |
Rep 37
i know the mirror tilts down for reversing. When you move back to park or drive it sometimes does not return to the position it was before tilting. I am going to give the cleaning a go, just waiting on some dielectric grease. |
