How to replace LCD on BMW Professional radio
06-26-2013, 01:47 PM | #45 |
1015
Rep 3,924
Drives: 330i, 135i
Wow great to know. Mine has a few pixels that go dark when hot. Doesnt really bother me since I can still read most of the display. But great to know this info about the fix. Thanks BeakerBoy!
06-26-2013, 02:16 PM | #46 |
Rep 18
I already re-installed my head unit, so no pictures taken. So, basically the 5 screws that you remove after removing the heat sink have no slots for a screwdriver or hex for allen wrench or torx. They almost look like rivets, but I can see they have threads. Very strange.
6MT, short shift kit, JB4, BMS Dual Core Intake, Mtech rear bumper
12-29-2013, 11:04 PM | #49 |
1926
Rep 13,134
google bmw cd 73 display
This is just one of the things that come up http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40 If you scroll down on this one at least 5 or 6 repair or part sources show up. |
02-18-2014, 01:44 PM | #51 |
Rep 2
Good instructions. Replaced a LCD that was getting muddled after 30 minutes. Bought LCD from Pixelfix based in Budapest. Excellent service, item took 4 days to arrive in the UK. Car is a 320D 2006 model.
03-29-2014, 10:19 AM | #52 |
Mystic Blue 2006 325i
Rep 25
Thanks
thanks to the OP I just replaced my display
A couple of things to add. When you remove the little circuit board on the circuit panel there is also a screw on the other side to remove Also there was clear tape on the connections that held the LCD cable to the circuit board connection. If you dont remove that clear tape you will pull all day on the cable and it wont come out of the connector. I did run into one small problem, so be prepared. One of the screws holding the heat sink was stuck pretty well. I ended up stripping the head. So I had to break out my easy out set to get the screw out. And then of course had to hunt for a metric screw to replace it. Lucky for me I had both the easy out set and a screw that fit. The detailed instructions really helped Thanks again |
04-14-2014, 11:53 AM | #53 | |
Rep 10
06-01-2014, 07:26 PM | #54 |
Fabricator
Rep 119
I just performed the DIY and the instructions and photos were superb. Thank you and now I have a nice display again.
It took about 1.5 hrs to complete from removal of radio to re-install. |
07-06-2014, 05:50 PM | #55 |
Rep 31
Drives: 2006 325xi Sedan Jet Black
UPDATE - place to purchase pixel board in USA
Just wanted to update all about where to purchase in USA market.
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en direct link to ebay seller http://www.ebay.com/sch/i.html?_saca...c&LH_PrefLoc=1 ebay listings.
2014 BMW X3 Mineral Silver (auto)
08-22-2014, 01:50 PM | #56 |
Rep 10
I just replaced LCD from HU and I have a problem with backlight. Sometimes it's dark then normal, then too bright etc. There are no rules! Everything is done by DIY. Any solutions, please?
02-13-2015, 03:30 PM | #58 |
Rep 17
Can I replace the entire front panel assembly?
I know this is a common problem and there are a lot of threads about this. Wondering if anyone has a quick answer here.
I picked up two salvage radios with working displays and I'm wondering if I can simply replace the entire front assembly and avoid taking apart the assembly to change just the glass. The only thing I am concerned about is where is the radio's anti-theft serial number stored in the circuity. If it's in the front assembly, then I'll have a radio with no security code. If the serial number and anti-theft circuitry is on the circuit board under the CD drive, then I'm fine swapping our the whole front assembly. |
02-13-2015, 04:05 PM | #59 |
1926
Rep 13,134
I don't think there are any anti theft codes for a BMW radio
If you disconnect the battery it doesn't ask you for one. Besides who would use it anyway. There is programming for options contained in the radio such PDC , ipod ,usb , Sos and Hi Fi or L7 or stereo output, so you can't just swap a radio into another car if it has different options and expect them to work or not throw error codes. The following file is an example of Hi Fi with SOS and Bluetooth phone. CODIERUNG_ERFOLGT codierung_erfolgt CDC nicht_aktiv AUDIO_SYSTEM pl2_hifi pl3_hifi SDARS nicht_aktiv PDC nicht_aktiv ACC nicht_aktiv STANDHEIZUNG nicht_aktiv AUX_RAD aux BAUREIHEX e9x COUNTRYCODE_RADIO us IBOC nicht_aktiv KEY_MEMORY_R aktiv MUTE_TIMES pl2 NACHLAUF_INT_R pl2 RIGHTHAND nicht_aktiv SOFTEN_ENTERTAINMENT_PDC nicht_aktiv TCU_ECE nicht_aktiv TIMEOUT_INT_R pl2 ULF_ECE nicht_aktiv BMW_AKD nicht_aktiv BMW_HOME_DEALER aktiv BMW_INITIALIZE aktiv BMW_MOBILE_SERVICE aktiv BMW_PHONE_SERVICES nicht_aktiv BMW_ROAMING nicht_aktiv BMW_TELESERVICE_ONLY nicht_aktiv RING_STATUS aktiv BLUETOOTH_RAD2 aktiv DISPLAY_LOGIC7 nicht_aktiv HI_TEMP_VOL_CTRL pl2_hifi pl3_hifi SMS_RAD2 nicht_aktiv PHONE_BUSINESS_R2 nicht_aktiv SVS_LOW_RAD2 aktiv BMW_ASSIST_RAD2 aktiv BMW_HOTLINE_RAD2 aktiv DAB nicht_aktiv CAR_COMP_ACTIVE aktiv TCU_JAP nicht_aktiv CONTACT_NR_DEALER aktiv CONTACT_NR_HOTLINE aktiv CONTACT_NR_MOBILE_SRVC aktiv ABS_VOL_GONG e91_hifi CROSSOVER pl2_hifi e90_hifi r56_stereo r56_hifi DELTA_GONG_ENT wert_0 DELTA_PDC_ENT wert_0 RATIO_AUDIO_SOURCES ece us VEHICLE_FILTERS e81_stereo e82_stereo e87_stereo e88_stereo e90_stereo e91_stereo e92_stereo e93_stereo pl2_hifi r56_hifi VOL_TEL_MAX stereo_mulf_e87 hifi_mulf_e87 top_hifi_mulf_e87 stereo_mulf_e90 hifi_mulf_e90 top_hifi_mulf_e90 stereo_mulf_e91 hifi_mulf_e91 top_hifi_mulf_e91 stereo_tcu hifi_tcu top_hifi_tcu VOL_TEL_MIN wert_0 VOLUME_TABLE e91_hifi MY_INFO_RAD2 nicht_aktiv V_INFO_RAD2 nicht_aktiv PHONE_PROF_RAD2 aktiv Last edited by ctuna; 02-13-2015 at 04:11 PM.. |
02-14-2015, 01:24 PM | #60 |
Rep 17
Well. it worked! I got a second radio and swapped the whole front panel assembly. Really easy to do. A few screws and only one ribbon cable that was easy to manage. my radio call history, bluetooth connections were all still there and working, so none of that was stored in the front panel. Now i need to wait for a hot day to see how the new panel holds up.
Hardest part was getting the HVAC panel to pop out. |
02-18-2015, 07:44 AM | #63 | |
323
Rep 568
Drives: BMW M4 DCT (F82)
Prying tool?
I have bad experiences with scratching cars' dashboards using flathead screwdrivers, so I am gonna invest in a proper tool this time cheers |
06-10-2015, 05:17 AM | #65 |
Rep 55
Hi! I have also tried to replace the LCD but have a problem. There is a white/orange film behind the LCD that has to be reinstalled to a new screen. Unfortunatelly my plastic film was stuck to the old LCD and got ripped while trying to remove it. Does somebody know where I could get a replacement film? What replacement should I use? A simple orange plastic film or what? Maybe it's possible to repaint the old one, but what paint should I use?
Currently I put the white paper instead, LCD works fine bus the screen has a very blue tint in direct sunlight, so I believe that film behind the screen is used to remove the bluish tint. Any help would be appreciated! |
Tags |
cd73, lcd replacement, pixel fade |
