07-13-2018, 06:37 PM | #45 |
Rep 24
Looks very good and I’m sure it sounds very organic... but one must keep in mind that these settings ought to be different sounding with engine on and road noise ,that results in higher noise floor....
07-13-2018, 08:56 PM | #46 |
12
Rep 103
I bought the mic and program after reading this thread.
Audiophile here looking for an excuse to buy a new toy.
2018 GT350
2019 Ford Raptor 2021 Porsche GT4 2024 M4 Comp Convert |
07-13-2018, 10:43 PM | #47 | |
94
Rep 249
At an off position, it at least gave me a starting point and you can go from there. |
07-13-2018, 11:16 PM | #48 |
94
Rep 249
If you were curious, here is a plot with the eq flat. The equalizer simply doesn't offer enough points for us to correct much. But my main focus area was around the 1K and 2K area. If you look at my settings in the previous post, I tried to bring down 1k and push up 2k. The after plot looks pretty much the same but instead of an 8 db drop, it is slightly smoothed to a about a 4 db change. In audio terms that is quite a bit.
In practice, when driving, just a slightly more scientific way to adjust the equalizer than turning up the bass and the treble (something I have seen done in many cars). Hope you found this at least interesting. |
Jocko78105.50 |
07-14-2018, 02:35 PM | #49 |
Rep 24
07-14-2018, 02:36 PM | #50 | |
Rep 24
Most importantly, how does it sound? And did you use any break in cd/s to warm up the system? |
07-15-2018, 10:03 AM | #51 | |
12
Rep 103
I've got my mic coming Tuesday and generating the test signal is the one thing I haven't figured out. Thanks, appreciate any tips.
2018 GT350
07-15-2018, 11:24 AM | #52 | |
94
Rep 249
Expert tip: I was told by a speaker designer to make sure to use uncorrelated pink noise for the most accurate results. |
07-15-2018, 12:37 PM | #53 |
131
Rep 227
Thanks!!
2018 M5 (current)
2012 535i Msport/Dinan (current) 2008 535i Msport (retired) 2003 530i (retired) 2000 C32 AMG (retired) |
07-15-2018, 06:44 PM | #54 |
12
Rep 103
Isn't an mp3 file by definition compromised? It have to be FLAC or lossless. There is a $15 CD test disc of pink noise on Amazon and Ebay that would seem to be better. Or the Stereophile test CD.
Probably doesn't matter given all the variables, but for us engineering/scientist types it would be more fun to use the CD. I know Audio Tools is a good generator. Could you stream the signal over Bluetooth while measuring? The CD seems the simplest solution.
2018 GT350
07-15-2018, 09:47 PM | #55 | |
94
Rep 249
Other things are too much hassle. But maybe I can try it later tonight to do it directly from Audio Tools. Edit: I checked a response curve I had for my main system. One of the curves generated was from an automated equalizer vs this MP3 and both produced something that looks almost identical. Of course, there were some variances but the main peaks and valleys were captured on both. So I wouldn't worry too much about the mp3 lossy file especially with what you are saying, there are too many other variables. Namely a big V8 sitting right in front of the stereo. Last edited by kdeleon; 07-15-2018 at 11:15 PM.. Reason: Added more detail |
07-16-2018, 12:22 PM | #57 |
376
Rep 1,223
What do you have the tone settings set to with these EQ settings. All flat?
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
07-16-2018, 11:50 PM | #58 |
94
Rep 249
07-17-2018, 12:49 PM | #59 |
376
Rep 1,223
Thanks, I meant treble and bass.
07-17-2018, 04:18 PM | #60 |
94
Rep 249
Sorry, misunderstood. I only tried upping the bass, but I didn't like it. More about preference. It felt like I was starting to cross the line to boomy (again with the engine off). Some might prefer it. I never really played with the treble as the roll off seemed appropriate.
07-18-2018, 12:22 AM | #62 | |
94
Rep 249
I assume there would be some change in the dead center. I just focused on the drivers seat as that is where I am. My passengers are free to take their own measurements and make recommendations. |
07-21-2018, 12:55 PM | #63 |
176
Rep 137
my system in my e93 was insane, my 550 sucked and my f10 sucked and my f90 sucks, youd think the price of the car they would give you a good sound system, its crap
08-15-2018, 11:13 PM | #64 |
Rep 25
Drives: 2019 X7 and 2020 X3 M40i
Got my M5 just yesterday. Really disappointed with the B&W for the money they charge. My old 997 with Bose had more kick in it. The B&W has a lot of purity for unplugged, jazz and classical. But it sucks for rock music. Bass is awful. I saw some of you decided to add a subwoofer. How complex is that to make it happen, wire it in?
08-17-2018, 12:30 PM | #65 |
376
Rep 1,223
Really? Did you set some of the EQ and tone settings to increase the bass? If the B&W bass "sucks", I would not want to be in a car that does not "suck".
BDWonder138.00 |
08-17-2018, 05:44 PM | #66 |
261
Rep 472
i agree. i don't think the B&W is the best ever but it certainly doesnt suck and is a vast improvement over the HK.
