08-10-2022, 09:57 AM | #23 |
989
Rep 1,807
I wonder how effective this will be. The person applied the tape to the tank as well as under the heat shield between the tank and engine or down pipes.
08-10-2022, 01:29 PM | #24 |
5293
Rep 10,686
There are 2 heat shields, one immediately over the turbos and cats and a second one above that. I would not bother putting adhesive heat tape on the first one since I think the adhesive would not stay.
The ultimate heat management would be DEI or similar GT22 turbo blankets, wrapped or coated catless downpipes, heat reflective tape under the upper heat shield, and heat reflective tape on the underside of the tank. |
Ryno 27252.50 ACashbuyeroc0.00 |
08-12-2022, 10:04 AM | #25 | |
22
Rep 49
here are pics of the work order F90 drivertrain.pdf |
08-12-2022, 10:18 AM | #26 | |
4152
Rep 7,167
Drives: F90 M5 / F15 50i
not sure what you meant but are you saying the coolant itself is corroding the tanks and causing leaks?
'07 Yamaha R1 (sold)
5tony152.00 |
08-12-2022, 12:56 PM | #27 | |
50
Rep 72
"CAUSE Aluminum corrosion in the charge air intercoolers, or in the radiator for the low temperature cooling is causing an unfavorable chemical reaction to the coolant." |
08-12-2022, 10:28 PM | #29 | ||
4152
Rep 7,167
08-13-2022, 09:42 AM | #30 |
989
Rep 1,807
Did you notice the color of the coolant before they changed it? I checked my coolant about a week ago since several postings have indicated coolant can sometimes be low. I noticed it to be low. I only have just under 4,000 miles on the 2021 car. I decided to call my preferred BMW dealership to see if they had coolant for purchase. The person on the phone asked about the year of the car and indicated there are two different coolants. He indicated newer cars now use a newer green coolant. The preferred dealership is further away than another dealership so I said what the heck I will go to the dealership closer my house. When I get there the parts person is like it does not matter which coolant you buy. He indicated you can even mix the blue and green. He was a very nonchalant type. Based on his extensive experience working behind the parts counter he was confident there is no difference between the green and blue. I tell him I want the green since that is what is in the car. He goes returns with a gallon and tells me it is the green. When I get home and open the jug it is the blue. I call back the next day and tell the idiot gave me the wrong coolant and they made it seem like it was a big deal to get the green coolant for the year and model car I have. The green seems to be a new coolant versus the blue.
F90jay28.00 |
08-13-2022, 12:20 PM | #31 |
5293
Rep 10,686
G12 is the new coolant. It is green. Backwards compatible but supposedly you should not put the older blue in a car for which green is specified.
08-13-2022, 12:27 PM | #32 |
94
Rep 75
Drives: 2019 M5, Ram 1500
Crap, now I am worrying about the blue coolant that is probably in my 2019 M5 and I just hit 27k.
08-13-2022, 07:51 PM | #34 |
516
Rep 382
Yup been there, done that with my old 2018. https://f90.bimmerpost.com/forums/sh...1739730&page=2
M5Neededi94.00 |
08-14-2022, 07:41 AM | #35 | |
989
Rep 1,807
08-14-2022, 08:02 AM | #36 |
5293
Rep 10,686
Even the blue coolant is pretty good. I’d be curious whether some previous owner or shop changed coolant with a non-BMW coolant.
08-14-2022, 09:50 AM | #37 |
721
Rep 786
That really sucks. I hope this isn’t an issue with my car as well. But this is one of the reasons I do an engine coolant flush on all my cars every two years despite mileage. Over time, through heat cycles, coolant will corrode internals.
08-15-2022, 12:16 PM | #39 |
4162
Rep 3,706
Drives: 2022 M5C
I can confirm my '19 base used blue, and my '22 comp uses green. Always dealer serviced at the same dealer, by the same technician.
Not a BMW guy...but certainly an M5 guy.
08-15-2022, 04:04 PM | #40 |
989
Rep 1,807
08-15-2022, 04:11 PM | #41 | |
1758
Rep 1,674
My car has just over 13k miles. One injector and Coil pack has already been replaced due to the leak. This is ridiculous. Should be a TSB or recall.
2020 M550 / Dark Graphite / Napa Saddle Brown / DHP Pkg / Exec Pkg / Luxury Pkg / Parking Asst Pkg
ResIpsaLoquitur4161.50 |
08-15-2022, 05:22 PM | #42 |
2284
Rep 3,307
EXACTAMONDO!!!! W T A F? (add Actual) to WTF?
BMW going to the bean counters and down the drain with them. At least the Electric BMW's won't have this issue. Mike
08-15-2022, 06:55 PM | #43 | |
4162
Rep 3,706
Drives: 2022 M5C
After PDI on my LCI (at a different dealership because it was purchased out of state), I asked the coolant level to be checked and topped off in my presence. They obliged (with green coolant), which I verified was in the tank to begin with. When break in service was done (with my above SA at my home dealer), it was topped off with green coolant.
08-15-2022, 07:00 PM | #44 | ||
4162
Rep 3,706
Drives: 2022 M5C
