10-11-2022, 02:33 PM | #23 |
5287
Rep 10,682
Yes, buying the rods is the cheap part. Engine out disassembly required. I’d probably just buy a built long block from Carbahn for $20k and install it myself. I can handle that but disassembling and reassembling the motor would be a challenge since I am just a DIYer and this is a pretty complex motor.
shawnhayes1838.50 |
10-11-2022, 03:29 PM | #24 |
165
Rep 762
The rods for the TU3 and TU4 engine are the same. It’s the only part that inside the engine that is the same.
10-12-2022, 08:18 AM | #25 | |
5386
Rep 3,796
04-29-2023, 05:33 PM | #26 |
48
Rep 97
Maybe this will help
from the engine pdf
05-07-2023, 06:22 AM | #28 | |
22
Rep 82
Will these work with a December build 2022 x5m Comp. If they do, may I please have pricing for these delivered to Australia. |
05-08-2023, 01:28 PM | #29 | |
5386
Rep 3,796
If you are unsure email the last 7 digits of your VIN to sales@evolveautomotive.com and one of my team can advise. |
AUSX5M22.00 |
05-10-2023, 05:43 AM | #30 | |
22
Rep 82
05-11-2023, 07:15 AM | #32 |
5287
Rep 10,682
If your idea of bolt in is to pull the engine, remove the heads, fully disassemble the bottom end, reassemble the bottom end, reinstall the heads, reinstall the motor. You are not far off a full bottom end rebuild at that point. The shop Evolve uses charges about $20k USD for this work, but that may include new pistons — if you are in that deep it makes sense.
06-09-2023, 05:27 AM | #33 |
5386
Rep 3,796
We are now offering the rods on their own:
https://www.evolveautomotive.com/pro...29fdc653&_ss=r and also as a package with Mr Vanos Arrow connecting rods Mahle rod bearing shells Mr Vanos Head studs Mr Vanos Custom head gaskets https://www.evolveautomotive.com/pro...5373e900&_ss=r The above pacakage is what we have in the Evolve F90 M5 as well as any customer builds we have carried out in the last year. |
06-12-2023, 07:26 PM | #34 |
130
Rep 216
Why would someone pull the motor out and only replace the rods for $17K???
Engine is open do it right with forged pistons and rods. The M5 tax is apparent for this price. |
06-13-2023, 07:51 AM | #35 |
5386
Rep 3,796
How long are those engines done right with forged pistons and lots of other parts changed lasting?
06-13-2023, 02:14 PM | #36 |
130
Rep 216
My experience when modding vehicles is failure comes and breaks the weakest link/part.
Yes you can upgrade rods but then you run risk of cracking a piston. This is of course tune dependent. Motor is out I would personally do them both. |
AUSX5M22.00 |
