BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    305 rear
      12-22-2023, 01:01 PM   #1
PDOT
Drives: 2021 M5C
305 rear
Is anyone running 305 rear on 20 x 11 wheels, and is lowered? I can't seem to find an answer to this.
      12-22-2023, 01:59 PM   #2
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
I have a Michelin SC2 305/30-20 on an 11" wheel, 29 ET. Lowered about 3/4" and no rubbing. Others on here have the 305/35 with no rubbing, not sure on their wheel width.
PDOT133.00
      12-22-2023, 03:10 PM   #3
bcparker2
105
Drives: BMW M5 (F90)
I have 305/35 20 on 11 inch wide they fit. When it comes time to replace I'm going 315/30 20, edit apologies I'm not lowered my bad.
PDOT133.00
      12-27-2023, 12:43 PM   #4
916_M5
IG: @M5RCY_
916_M5's Avatar
Drives: BMW F90 M5
itll fit
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off
Dura-Coating - code: M5RCY for 20% off
      01-03-2024, 11:38 PM   #5
rumeet14
Drives: BMW m5c
bmw m5  [0.00]
I was running 305 30 zr 20 on my 11s
      04-13-2024, 12:10 PM   #6
paulh@zyllion.com
Drives: BMW M5 F90
275/35R20 front, 305/30R20 rear
      04-13-2024, 12:39 PM   #7
pbonsalb
5287
The 305/30 rear matches up pretty well with the 275/35 front. I want a little more meat up front as well, but that means either 285/295 in 35 series or 295/305 in either 30 or 35 series and 35 series may cause running in the front and rear. Have to decide this year.
      04-13-2024, 02:47 PM   #8
PDOT
Drives: 2021 M5C
I’m actually at the track now running 295/305 30. No problems so far.
      04-13-2024, 11:30 PM   #9
pbonsalb
5287
What I would be concerned about for my street driving with the 295/30/20 front and 305/30/20 rear is ride quality. Will all the comfort be gone? The smaller overall diameter also effectively shortens gearing and maybe with my engine mods I will simply have more traction troubles.
      05-17-2024, 04:25 PM   #10
CrashCade
113
Drives: '19 M5 Comp,
So I ordered some ps4s in a 305/30r21 for my 21x11 rears. My offset is +24. I am lowered on H&R M550 springs and could set the car down off the jack due to the tire hitting the fender. Now, there are guys running a 305 out there. I was in discussion with on and the only difference is he was running a +28 rear offset.
I know you can get away with a 285/305 with the right offset.
Once I sell this set of Rex Racing Staggered 20”s I will be ordering some Triton 20” in the right offsets so I can safely go to 305s.
      05-17-2024, 04:27 PM   #11
CrashCade
113
From OEM 285/35 to a 305/30, you are only losing .3” in sidewall height. I would say the traction improvements will far outweigh any quality change due to sidewall heights.
      05-17-2024, 04:40 PM   #12
CLEbmw
Drives: BMW 328d, X7 M60i
I have Vossen HF-5s in 21. Tried 305 rears but they rubbed, just slightly. Dropped to 295s and no issues.
