BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Spark Plugs - Did you go aftermarket or OEM?
      04-05-2023, 08:37 PM   #1
dcohen13
Drives: M5 Comp
I am coming up on 30K miles and I am due for spark plugs. Anyone have experience with NGK or any other brands? Or should I stick with BMW Genuine?
Thanks!
      04-05-2023, 08:56 PM   #2
pbonsalb
5287
I think NGK makes the stock part. Buy it from BMW if you like to pay more. If you have more than a stage 1 tune, consider a colder plug like the 97506. If not, the stock heat range is fine.
dcohen13682.00
      04-06-2023, 08:03 AM   #3
AHall
989
Drives: 1993 Nissan 240sx
Is this not covered by the service agreement?
      04-06-2023, 09:26 AM   #4
dcohen13
Drives: M5 Comp
I did not purchase a service agreement, just CPO for warranty issues.
      04-06-2023, 09:27 AM   #5
dcohen13
Drives: M5 Comp
Appreciate the honesty! Aftermarket it is then. I am stock tune as well. Thanks!
      04-06-2023, 09:31 AM   #6
pbonsalb
5287
Make sure you have a thin wall 14mm 12 point deep socket. Regular wall is too big.
dcohen13682.00
      04-06-2023, 11:22 AM   #7
Ropes
Ropes's Avatar
Drives: 2020 M4 CS
+1 NGK
You can swap the plugs without having to drain and remove the radiator tank.
dcohen13682.00
      04-07-2023, 05:46 PM   #8
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Originally Posted by Ropes View Post
+1 NGK
Why would you drain the radiator tank?
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      04-08-2023, 07:19 PM   #9
Ropes
Ropes's Avatar
Drives: 2020 M4 CS
Per the instructions I read which they call for removing the reservoir.
dcohen13682.00
      04-10-2023, 08:38 AM   #10
Maxlude
United Kingdom
158
Drives: E90 330D_SE_Man, F90_M5C
Just had mine done at dealer at 19k miles.
Kept the originals too as such low miles. Tbh, they look high quality parts and no reason to change unless there's an ignition related issue or tuned.
The plugs that came out of my UK 2019 Comp are Bosch ZR5TPP3320
dcohen13682.00
      04-10-2023, 09:37 AM   #11
pbonsalb
5287
19k might be a little premature, but maybe you were at the 3rd oil change because you don’t drive much. The gaps on my plugs and opened 1-2000ths based on my measurements at 26k.
      04-10-2023, 09:51 AM   #12
Maxlude
United Kingdom
158
Yep, you are right. It was done as part of the third oil change.
It's only at 19k miles I don't drive it much since covid. When I bought it in 2019, I was doing a 175mile trip to site on a Monday and same back on a Thursday. It was a fantastic car for that. An awesome blend of comfort, luxury, safety, practicality with a sporty flavour
We have an electric car for local journeys.
      05-25-2023, 07:54 PM   #13
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
Looks like it's covered by the standard Ultimate Care Maintenance Programs 36month/36K warranty at the 36 month oil change service.
      05-31-2023, 02:13 PM   #14
916_M5
IG: @M5RCY_
916_M5's Avatar
Drives: BMW F90 M5
Tuned on Carbahn stage 1 and went with NEW OEM plugs at 40k gapped to .022
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off
Dura-Coating - code: M5RCY for 20% off
      06-01-2023, 08:10 PM   #15
Rup91
69
Drives: 2018 M5/ 2024 X7 40i
What is the stock gap? I bought some off ebay using correct bmw part #, just want to make sure that they are gapped properly before I tear everything out.
      12-25-2023, 09:27 PM   #16
Eljeffrey13
Eljeffrey13's Avatar
Drives: Bmw f90 M5
I just got the carbahn stage 1 tune im doing spark plugs this week, so u recommend oem just gapped different or after market gapped a certain way?
Jeffrey jaquez
      12-26-2023, 06:39 PM   #17
Holset
Sweden
279
Drives: F90 M5 Comp LCI
I would recommend to use stock plugs/gap unless you start having spark trouble relating the plugs.
      01-02-2024, 11:56 AM   #18
916_M5
IG: @M5RCY_
916_M5's Avatar
Drives: BMW F90 M5
Really personal preference.
      01-02-2024, 09:56 PM   #19
Eljeffrey13
Drives: Bmw f90 M5
I went with ngk one step colder, my mechanic recommended one step colder when tuned
Jeffrey jaquez
      01-02-2024, 11:01 PM   #20
Rup91
69
If I went with NGK on stock next time, would that be an issue? Do you have to gap them? If so, to what?
      01-03-2024, 10:21 PM   #21
Eljeffrey13
Drives: Bmw f90 M5
If you are stock i would stay with the stock plugs, no reason to change, car might even run alittle rougher if u switch being stock
Jeffrey jaquez
