BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    F90 not making full power
      08-15-2022, 10:27 PM   #1
jivom5
74
Drives: audi a7, c7 grandsport
Last night around 3am kn my way home from work I decided to rip the car a bit on the highway, long story short with dsc completely off the car in sport + the boost gauge didnt go past 15lbs of boost and the horsepower gauge was reading below 480. And now it feels sluggish temps were about 70f outside.
Anyone experienced this before?
The cars completely stock with no trouble codes/ check engine light
      08-16-2022, 06:57 AM   #2
pbonsalb
5288
Do you have a really good scan tool that can see pending codes?
      08-16-2022, 02:13 PM   #3
jivom5
74
i scanned the codes with obdlink nothing came up, however i took the car for a few laps on the highway to burn some gas, after about 40 miles it was still the same, so i filled up shell 91 and to my surprise after about 15 miles the car started to feel normal again the horsepower gauge went from under 480 to just below 640 doing some heavy pulls
      08-16-2022, 02:27 PM   #4
DryBark
DryBark's Avatar
162
Drives: M5 / X5
2023 BMW X5  [0.00]
2018 BMW M5  [10.00]
What did you have in it before?
imolaa_m5124.50
      08-16-2022, 02:33 PM   #5
jivom5
74
i always fill up 91 as that's all we have available in california
      08-16-2022, 07:26 PM   #6
pbonsalb
5288
Maybe it was some bad gas or it was really hot and 91 was not good enough to make full power?
      08-16-2022, 08:02 PM   #7
jivom5
74
the boost was not going past 15 lbs it was close to half and was hesitating to accelerate past 4000 rpms
      08-17-2022, 05:57 PM   #8
patrickkc
28
Drives: E63S , C63 , Cayenne
This has been happening to me too. 2019 M5comp. 0-100 times pretty bad.
Not sure what's wrong, no lights on or anything. I feel there might be a bog from 1st to 2nd.
No tune in the winter, with winters and wet ground, managed 3.88 0-100
After tune, OTS 91 BM3 stage 1 - 3.6-4.5s 0-100. ( did a few launches ) Thought the tune was bad, so I took the tune off.
No tune on summers ( brand new PS4S ) 0-100 3.5s.
Put the tune back on last week, 0-100 3.47s.
I thought it was fuel before, but I've been through a few tanks with same results. Reading around, it might be the high and low pressure fuel pump issues, since my car sounds like it's about to die during some startups.
      08-17-2022, 11:33 PM   #9
jivom5
74
I’m starting to think the same, my horsepower guate isn’t passing 320 now, I did a 0-60 run and it was about 3.6 previously it was 2.9-3.2
      08-18-2022, 02:21 PM   #10
Enjoiii
Enjoiii's Avatar
38
Drives: G80
If you have cold start deleted, undo it. I had it deleted, car acted like it was gonna die everytime i turned it on warm. Reversed it and left cold start, no problems anymore
Appreciate 2
Holset278.50
916_M5366.50
      08-18-2022, 03:37 PM   #11
patrickkc
28
It seems we may have the same problem. Does your engine struggle to startup? I will bring my car in to BMW and see if they can replace the high and low fuel pumps. It seems quite a bit of people have problem with the pumps. Might be related. At this point, I'm hoping it is.
Nope, cold start is on. Only thing I've touched for the tune are the burble settings. You're right about the dip in RPM is during warm starts . Cold starts don't seem to have this problem. The reason I think it's not tune related is because my friend also has a '19 M5C completely stock and does the same. Sometimes his is even worse as the engine will stall completely and need to restart. He never brought the car in for it so not sure what the dealer is gonna say about mine.
      08-18-2022, 05:23 PM   #12
shawnhayes
1839
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
Computer is pulling power. The reason may be sophisticated. First troubleshooting step to me is to return EVERYTHING to stock and see if it goes away.
Shawn
      08-19-2022, 12:04 PM   #13
jivom5
74
my cars a 21 lci so it isnt tuned, but i think i figured out the issue, my mechanic plugged in a external ethanol sensor and my ethanol content was close to e60 so we burnt all the gas in the tank and filled up fresh 91 and it seems like its back to normal
      08-19-2022, 12:39 PM   #14
shawnhayes
1839
dafuq?
Did you accidentally put in a tank of E85?
Shawn
MNoob1539.50
      08-20-2022, 12:24 AM   #15
patrickkc
28
Glad you got yours figured out. I did some random pulls tonight and even with tune, the HP gauge only going up to like 400 something.
      08-20-2022, 02:05 AM   #16
jivom5
74
Originally Posted by shawnhayes View Post
dafuq?
Shawn
No lol, I always fill up at the same station, they have e85 but I’ve never tried it. Im thinking they may have mixed up the barrels or something. But the car runs perfect again
      08-21-2022, 04:30 PM   #17
shawnhayes
1839
They must have. That's a ridiculous difference. Glad you got it sorted and it's okay.
Shawn
      09-17-2022, 12:49 PM   #18
M5Neededi
M5Neededi's Avatar
Drives: 2019 M5, Ram 1500
2019 BMW M5  [0.00]
I had limited power issue on my 19'M5 for over a week. Then the problem went away on it's own (I did fill up with different gas before the problem cleared up). There was no CEL or messages. What scan tool do you guys use/recommend?
      11-29-2023, 03:12 PM   #19
HelloM8s
Drives: 22 M8C, 20 F-150 Limited
Anyone get this figured out?
I have a M8 GC Comp which is basically the same as the M5 F90 and I'm having the same issue.
Car drops boost at high RPM's. Logged it with an Autel scan tool and sure enough it goes from 20psi to 14-15 psi at high RPM. More noticeable on 4th and 5th gear. 5th gear does not go a pound over 16psi the entire pull.
I got new Dinan Coil Packs, NGK plugs, Re-fueled elsewhere with 93, have tried 3 gallons of E85 for E20 mix and still no luck with the car dropping boost.
      12-03-2023, 05:34 AM   #20
FJPM
Belgium
Drives: 330 D F 30 and F90 M5
2022 BMW M5  [0.00]
I got a subjective (nothing measured) loss of power with my '22 LCI M5. I suspect also that it is coming from poor quality gas: i filled up always with 98 octanes (the top grade in Europe with 5 % ethanol) but this time low cost... I will see if power comes back when I will empty the tank and fill it up with premium brand. I hope that the filter has not been clogged...
      12-07-2023, 06:45 PM   #21
916_M5
IG: @M5RCY_
916_M5's Avatar
Drives: BMW F90 M5
Same here. Leave it on.
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off
Dura-Coating - code: M5RCY for 20% off
      12-27-2023, 10:19 AM   #22
Alan l.
Alan l.'s Avatar
5507
Drives: 2020 F95 X5M Competition
Check your intercooler coolant tank to see if you are low. I noticed the same on my X5M after the dealer forgot to refill my coolant and the car would pull power. very noticable if you are on it and its upshifting. Feels like the power just hits a wall. Sure enough when i checked the tank it was empty! Ever since i refilled/bleed the system the power is back to normal.
