08-09-2022, 09:43 AM | #2 |
162
Rep 254
Drives: M5 / X5
There are a few blown engines on this site right around that mileage mark due to this.
08-09-2022, 09:53 AM | #4 |
2840
Rep 5,142
Just look on the g30 forums, plenty of us that experienced this including myself
In my case it was the 2 reservoirs having a minute crack . So only very small amounts escaping but over time it will trigger low coolant warning Fixed under warranty for me Don't be robbed off by dealershipnsaying a small leak is normal as it isnt |
08-09-2022, 10:37 AM | #5 |
2274
Rep 3,302
No leak is 'normal.' Poor design.
Mike
08-09-2022, 11:11 AM | #7 |
4148
Rep 7,164
Drives: F90 M5 / F15 50i
heat soak is killing the cheap bmw plastics. always has and always will. especially the hot v design. cheap plastic on some oil return lines in my X5 50i disintegrated only to find out they replaced with new rubber lines 6 months after my build date.
'07 Yamaha R1 (sold)
08-09-2022, 11:28 AM | #8 |
162
Rep 254
Drives: M5 / X5
08-09-2022, 12:03 PM | #9 |
988
Rep 1,806
08-09-2022, 01:43 PM | #11 |
286
Rep 356
The coolant tank leak on mine at around 25,000 miles led to failed direct injectors. The first dealer (who had the car for 4 weeks) told me that my head gasket was blown and wanted $8,000 to fix it due to the fact that my car was flagged for a tune and they claimed the tune caused the head gasket to fail which led to "overpressurizing" the coolant tank and caused it to crack. The second dealer replaced everything under warranty because, surprise, my head gasket was not blown and this is a known issue.
Subaru335i1.00 |
08-09-2022, 02:05 PM | #13 |
22
Rep 49
1. got low coolent warning
2. went to dealer, topped off (turbo coolent) 3. same day, drivetrain malfunction, lost power, limp mode 4. back to dealer, turns out coolent leaking, affecting turbos, and needs to replace radiator and a whole bunch of things (dont know full details yet) 5. BMW authorized repairs, parts took about a month to arrive 6. once fix is done will update. 32K miles, 2018 F90 |
M5Neededi94.00 |
08-09-2022, 02:18 PM | #14 |
286
Rep 356
Yes - multiple injectors were replaced. I cannot say for sure exactly what was wrong with them but they replaced all 4 on the driver's side of the engine.
08-09-2022, 02:30 PM | #15 |
988
Rep 1,806
I wonder what it will take for BMW to be proactive and resolve this issue. Replacing the failed tanks with an exact copy will likely fail again.
08-09-2022, 04:09 PM | #16 |
286
Rep 356
08-09-2022, 04:37 PM | #17 |
162
Rep 254
Drives: M5 / X5
Someone took theirs out and coated it with something, can't remember what. I think another person had one custom made as well.
08-09-2022, 09:16 PM | #18 |
409
Rep 162
I went on holidays for 2 weeks and my car sat in my garage for that time. Temperature in garage is roughly 26°C. When I got back I fired the car up and got a low coolant warning. I topped up both coolant locations, the main needed roughly a cup and half. Not very much. Should I be concerned? Car has roughly 22k miles on it. A low coolant warning came on one other time as well.
2020 M5 Competition
08-09-2022, 10:26 PM | #19 |
125
Rep 149
Happened to my LCI brand new 22 at just 1.7k miles. The cap on the coolant tank failed and started leaking coolant out the expansion dripped down into all 4 injectors in that area. Was replaced by bmw under warranty but shouldn't be happening I second a aftermarket tank / cap solution
Current: ?22 F90 M5 Comp Individual Imola Red
2018 c63s coupe sold |
M5Neededi94.00 |
08-10-2022, 02:44 AM | #20 |
253
Rep 663
Thanks for the responses. I never did get the low coolant warning. I brought the car in for brake fluid service and the tech noticed the leak near the fill cap. The expansion tank was replaced and injector wells had to be cleaned due to the leak. Definitely have concerns about this happening again. I just bought the car out of my lease, however did opt for the extended maintenance and warranty thankfully.
08-10-2022, 09:02 AM | #21 |
4148
Rep 7,164
it was heat reflective tape. its what comes on the Eventuri air box's
Derosnec79.00 |
08-10-2022, 09:56 AM | #22 |
5275
Rep 10,672
It was me. DEI 2” fiberglass heat reflective tape. I be also applied it to the underside of the upper metal heat shield (the one the tank bolts to). I used a new tank since my car was 4 years old and it seemed like a good idea to replace it preventatively based on what I read here on motor failures due to coolant leaks.
