BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Leaky coolant tank replacement?
      08-15-2023, 10:48 PM   #89
afo818
afo818's Avatar
Drives: 2019 BMW F90 M5 Competition
2019 F90 Comp  [8.50]
Originally Posted by pbonsalb View Post
Not for me. I can handle this no problem and like the M5. Changed my coolant tank, reduced the heat under it, contained the heat, reflected the heat. Family sedan that does near 140 in the quarter with mods is pretty exceptional.
Do you have the ptp turbo blanket?
LOYALTY AUTO GROUP
      08-16-2023, 07:11 AM   #90
pbonsalb
5266
No. I have DEI turbine blankets for the little GT22 turbos, wrapped primaries and secondaries, and heat shield tape under the upper sheetmetal and on the bottom and sides of the tank.
The PTP blanket just drapes over the turbines and cats. It will reduce heat rising to the coolant tank. But it also blankets heat in the V of the V8, probably increasing thermal load on the engine coolant and oil. The more ideal approach in my opinion is to contain the heat in the turbine and piping so it goes out the exhaust to the extent possible.
The best system would also include a coated manifold. But that would be a lot of work.
Reducing the restrictions in the exhaust that trap heat also helps, but affects the warranty and legality.
Appreciate 3
Maverik2594144.50
afo818259.00
      08-16-2023, 01:06 PM   #91
afo818
afo818's Avatar
Makes sense. I’m currently catless “thermal coated” dinan x pipe down to akrapovic mufflers. No issues with the tank as of yet but I also do not daily anymore. Let’s see how long she lasts
LOYALTY AUTO GROUP
      12-06-2023, 10:38 PM   #92
afo818
afo818's Avatar
Sales@RKautowerks
2 weeks on the car 0 hiccups.
This should be the first mod for anyone with this motor now that it’s available
LOYALTY AUTO GROUP
Appreciate 2
tintboy52.00
F30Andy1778.50
      12-06-2023, 10:39 PM   #93
pbonsalb
5266
Looks good in anodized black!
afo818259.00
      12-06-2023, 10:40 PM   #94
afo818
afo818's Avatar
Blends right in, no need to disturb the factory look imo
LOYALTY AUTO GROUP
      12-07-2023, 12:21 PM   #95
Mpire AutoWerks
Drives: M8 Comp
I Came up with A COOLANT TANK RELOCATION Kit for any one interested My Kit involves Moving the Tank to A completely New Location because of the Fact that the Tanks Crack and Also Bleed off coolant from the cap I vill have a install Video up on YouTube don’t on my page
https://youtube.com/@mpire__autowerk...QwLdejL9Xk-fz6
Appreciate 3
afo818259.00
vanos8466.00
F30Andy1778.50
      12-12-2023, 07:26 AM   #96
dasvolk
The King of Speeding
dasvolk's Avatar
19
Drives: E60 M5, F90 M5C
2006 BMW M5  [0.00]
Very clever, looks like you're using off-the-shelf parts as well. What'd you do to accomplish this?
      12-12-2023, 08:17 AM   #97
pbonsalb
5266
I assume he wants to profit from his work by selling a kit rather than providing the details so you can DIY, but should not be hard to identify the tank and re-route or extend or cut hoses as necessary. Under those plastic hose fittings the clip-fit in place is a hose barb that you can reuse for a new hose or on a cut hose, and BMW sells the clamps or you can use a generic oettinger clamp that fits.
I thought about this at one point, but was leaning towards the cavity behind the shock tower instead. Probably this guy did as well and determined that just in front of the tower was easier. You do have to give up your stock intake boxes and use filters in the engine bay like CTS Turbo, BMS and MAD sell or the rubber or metal tubes leading to cone filters behind the front grilles that several other vendors sell.
      12-29-2023, 07:39 AM   #98
Mr. Jonathan
48
Drives: 2020 BMW M5 Comp
So are you going to post a DIY video or just the short? I didn't see where this "kit" is sold. Not sure if your plan is to monetize your solution but I cant give you my money as is....
      12-29-2023, 09:07 AM   #99
pbonsalb
5266
The kit is for sale. I have seen it advertised but can’t remember whether it was here or on a Facebook group.
      12-29-2023, 11:45 PM   #100
ST3
ST3's Avatar
340
Drives: F90 M5
Anyone have any higher mileage stories where they have yet to need a new tank? (50k mile or more). If so, do you live in a cooler climate?
      12-30-2023, 04:36 AM   #101
AHall
983
Drives: 1993 Nissan 240sx
I have almost 3 years with no issues, but not many miles.
      12-30-2023, 07:53 AM   #102
fun2drv
fun2drv's Avatar
Drives: '23 M5 Comp
2023 BMW M5  [10.00]
2023 BMW M5  [0.00]
The original tank in my 2019 failed at 51K miles right when I was in the middle of selling the car…
      03-22-2024, 11:28 AM   #103
oneofew
Drives: 23 M5 Comp
23 M5C under 5K mi, hardly driven in hot weather already starting to seep .
afo818259.00
      03-23-2024, 12:34 AM   #104
Demon Barber
292
Drives: 2018 M5, 2022 911 Turbo S
I replaced my 2018 coolant tank with the new part number in 2023, and I've already seen signs of leakage around the cap. This is apparently going to be an ongoing issue.
      03-23-2024, 09:04 AM   #105
pbonsalb
5266
My theory on the cap is excess pressure from expansion due to either heat or overfilling it. It can vent all over the place or just dribble out the channel and down the side and then travel in it along the seam. Reports are that the seam itself has leaked in some cases.
      03-23-2024, 10:16 AM   #106
Demon Barber
292
Agreed. Makes me reluctant to install a stronger aluminum tank because then some other plastic coolant system component may start leaking elsewhere.
      03-23-2024, 11:02 AM   #107
pbonsalb
5266
Even the $1000 aluminum tanks - I think there are 2 now - use the stock cap so venting should still occur if that is the issue. But the aluminum tanks do address the reports of pinhole leaks developing along the seam on the plastic tanks. I am curious whether those leaks also develop due to excess heat or pressure or a combination of both.
      03-23-2024, 11:19 AM   #108
Demon Barber
292
Interesting. Well as long as there is some pressure venting, maybe an aluminum tank will be the way to go, if I can confirm that the replacement OEM tank leaks along the seams too, and not just around the cap.
      04-12-2024, 09:30 PM   #109
SeatownF90
SeatownF90's Avatar
47
Drives: F90, 958
Well, it finally happened. I checked about a week ago and it was fine. 2019 comp, 28k miles after some spirited driving in sports plus. Splash marks indicate its from the seams for me rather than the cap.
Appreciate 2
afo818259.00
GTTC59.00
      04-13-2024, 03:57 AM   #110
Justao
Justao's Avatar
United Kingdom
398
Drives: BMW M8 F91
RS GHIGO use its own cap
