BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Yellow CEL, no idrive message
      02-04-2023, 06:45 PM   #1
spuntyb
spuntyb's Avatar
Drives: 2019 F90 Competition
Bought the car new in October, and a few weeks later, there was a cold snap, and the CEL came up, with no idrive message, and no change in how the car drove or functioned. Went away when it warmed up a few days later.
Did it again a few days ago with this recent cold snap (I’m in northern NJ), and isn’t going away. It seems it’s related to the thermostat? Although the temp readings are normal, and the car warms up normally. In any case, has this happened to others? I found some threads where the same thing seemed to happen, but not sure what to do other than buying a tool to clear the code.
I wouldn’t mind it, but obviously with a CEL, remote start doesn’t work, and in near 0 temps, it’s when I need it most.
Any thoughts?
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold)
2018 F80 ZCP TB|SS (sold)
2015 F30 335 AW|CR (sold)
2015 F31 MG|CR (sold)
2011 E90 JB|Oyster (sold)
      02-04-2023, 08:38 PM   #2
pbonsalb
5287
Could be as simple as not fully tightening the gas cap sometimes. But it would be best to use a higher level scan tool to pull the codes. You will then likely see a shadow code.
spuntyb4066.50
      02-04-2023, 09:51 PM   #3
shawnhayes
1839
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
Very likely an emissions code with no idrive message. Got the same for me with "bank balance mismatch" years ago after running WOT on the track for a long time. Dealer pulled and fixed. Check codes as suggested.
Shawn
spuntyb4066.50
      02-04-2023, 10:55 PM   #4
spuntyb
spuntyb's Avatar
Thanks folks!
      02-07-2023, 10:08 AM   #5
spuntyb
spuntyb's Avatar
Following up.
Got the code P04FC “Manufacturer Control”, which the tool refused to clear. The last time it happened, it was when ambient temps were below 40. It started warming up a bit the other day, and sure enough, it went away yesterday.
There’s a thread about folks getting non-iDrive CELs with Eventuri CF turbo inlets installed, which I have (not the intakes though), but last time was before I had these installed, so not sure they factor in.
shawnhayes1838.50
      02-07-2023, 12:52 PM   #6
pbonsalb
5287
https://f92.bimmerpost.com/forums/sh....php?t=1979903
spuntyb4066.50
      02-07-2023, 01:11 PM   #7
spuntyb
spuntyb's Avatar
Originally Posted by pbonsalb View Post
Yeah that’s the one I was referencing, but this happened before I had those installed. The only connecting factor is it happens at low temps, which isn’t referenced in this thread, which is why I feel like it’s a sensor, and of course the next time I bring it in for service, it’s unlikely this CEL will be back…
Weird
      02-07-2023, 03:12 PM   #8
pbonsalb
5287
What scan tool are you using? Maybe a higher level one would help zero in? Cold can cause issues. One code I started getting in late fall had to do with wastegates and boost reaching a limit. I have a tune and a JB4 controlling meth and adding boost on top of the tune. I gradually reduced the JB4 boost additive from 5 psi to 2.5 psi until the code stopped appearing. I will look into this at some point - there is probably a fix.
      02-07-2023, 03:47 PM   #9
spuntyb
spuntyb's Avatar
It’s a cheap one I got years ago for like $25 on Amazon. I was thinking maybe the same thing, like I just need a slightly more robust tool. Will give that a shot this weekend. Any recs?
      02-09-2023, 06:42 AM   #10
pbonsalb
5287
I would get one with bmw specific software. Some download factory software but it can be complicated to use. The Foxwell NT510/520/530 are a good value in little hand held units and you get a free brand specific module when you register it. If you step up to a small tablet like an Autel 808, you must pay annual subscription costs — I think they are cloud based now.
spuntyb4066.50
      02-09-2023, 07:33 AM   #11
spuntyb
spuntyb's Avatar
I would get one with bmw specific software. Some download factory software but it can be complicated to use. The Foxwell NT510/520/530 are a good value in little hand held units and you get a free brand specific module when you register it. If you step up to a small tablet like an Autel 808, you must pay annual subscription costs — I they they are cloud based now.
I’ll give that Foxwell a shot, thank you!
      03-28-2024, 04:40 PM   #12
SeatownF90
SeatownF90's Avatar
47
Drives: F90, 958
I recently got this CEL with P04FC. Mods are bms stage 1, dinan turbo inlets, mad secondary dp and dinan x pipe. CEL was on for a day then suddenly went away by itself. Only change I can remember is filling up at a different gas station.
      03-28-2024, 08:34 PM   #13
pbonsalb
5287
Likely related to the Dinan inlets — there were some bad batches that leaked. It’s a crankcase vent code.
      03-28-2024, 08:50 PM   #14
spuntyb
spuntyb's Avatar
in my case it was my Eventuri turbo inlets. i had one of the first batches and they apparently shipped with faulty exhaust gaskets that Eventuri replaced. once I popped the new gaskets in, the CEL never came back:
https://www.bimmerpost.com/forums/sh...php?p=30524652
