08-07-2023, 11:47 AM | #67 |
5281
Rep 10,678
To me, the diagram shows water from the primary radiator cold side entering the auxiliary radiator, traveling across it to cool further, and discharging into the path to the hot side of the main radiator where it will help reduce the main radiator temp as it travels across to the cold side of the main radiator and is discharged again into the path for the hit side of the main radiator. Seems plausible to me for an auxiliary radiator.
The engine cooling system has a primary radiator and an auxiliary. The intercooler cooling system likewise has a primary radiator and an auxiliary radiator. That also makes sense to me. I don’t see the ECU cooling lines in the diagram, but assume they are connected to the intercooler coolant system that runs at a lower temperature. The ECU lines look just like the lines going into the intercooler reservoir but I did not actually trace one all the way. |
08-07-2023, 11:58 AM | #68 |
335
Rep 411
Drives: 23 M5C, 19 X5
This shows the water warming up as it passes through the radiator which doesn't make sense:
I think ECO cooling was in the F10 and whatever SUVs early on. Not on the F90. |
08-07-2023, 12:35 PM | #69 |
5281
Rep 10,678
The coloring of the diagram may not be completely accurate given the routing. We have water from the cold side of the primary engine coolant radiator going through the auxiliary radiator and merging with the hot flow entering the hot side of the primary radiator.
The coloring could go either way. This way it matches up with the primary radiator in/out colors. There is ECU cooling on the F90. I have removed the ECU before and pulled out the coolant line. I think the line comes from the intercooler coolant circuit. |
08-07-2023, 10:44 PM | #70 |
17
Rep 203
Drives: f10 M5
08-14-2023, 07:49 AM | #71 |
91
Rep 132
Coolant catch pans soon will be here in US.
Will be sold with all necessary mounting hardware as well as installation instructions |
8
carseatsm5848.00 Rup9168.50 afo818259.00 DocsF90M526.00 fun2drv262.00 DarkishM5C311.50 NoMods1123.50 jwilsonf900.00 |
08-15-2023, 12:35 PM | #74 |
5281
Rep 10,678
The tank part number apparently change but people with the new tank have reported the same issues. It does not seem to affect every car.
08-15-2023, 12:56 PM | #75 |
44
Rep 134
Mine is currently off the car. I’m replacing plugs and coils from this issue with the previous owner going unchecked. Misfire in 5-6 with dried coolant remnants. I’m interested. What’s your price shipped to 35756?
08-15-2023, 02:42 PM | #76 |
91
Rep 132
Price will be around $400-500 for the kit. Unfortunately I think I won’t have them in stock before you finish the repair. However it’s not hard to install it after you have new tank installed.
08-15-2023, 05:14 PM | #77 |
44
Rep 134
While I think the product is a great idea, I don’t see them selling at that price point. Thermoplastics are extremely inexpensive and these appear to be molded based on your CAD design. We all value our time and effort, but you could have these on pretty much every single forum member’s car, or you could have that batch just sitting on the shelf collecting dust. If these were CFRP, they MIGHT carry that value. I mean this with no disrespect whatsoever, but that’s $100-$150 if you ask me, unless I’m missing something… Unfortunately, I’m out at that price range.
08-15-2023, 05:38 PM | #78 | |
91
Rep 132
08-15-2023, 07:27 PM | #79 | |
136
Rep 494
08-15-2023, 07:30 PM | #80 |
5281
Rep 10,678
Might find a tank for $150. This shell with a drain could be good for out of warranty owners who don’t look under the hood very often.
08-15-2023, 07:44 PM | #81 | |
91
Rep 132
You can convert and see how much it retails right now in Russia 1evel.ru/product/level-performance-nizhnyaya-chast-rasshiritelnogo-bachka-bmw-f90/ We will try to bring the product close to this price here in US. Thank you. |
08-15-2023, 07:49 PM | #82 | |
519
Rep 389
I definitely agree with you on this. Most of us on here care about our cars so we check them consistently but for someone out of warranty who doesn’t wanna look then maybe that price is justifiable. |
08-15-2023, 07:54 PM | #83 |
136
Rep 494
08-15-2023, 08:18 PM | #84 |
4151
Rep 7,165
Drives: F90 M5 / F15 50i
///M tax for sure.
'07 Yamaha R1 (sold)
08-15-2023, 08:21 PM | #85 | |
4151
Rep 7,165
08-15-2023, 08:42 PM | #86 |
5281
Rep 10,678
This has me reconsidering converting to Evans coolant, which runs at maybe half the pressure of stock coolant. I have run it in my E36 M3 turbo since 2006 and ran it in my E90 M3 for 6 or 7 years. Probably not a good for track use since it is apparently flammable. I have a tank of gas in my car that is flammable … as well as an aftermarket water/meth system filled with 70% meth that is flammable.
afo818259.00 |
08-15-2023, 08:44 PM | #87 | |
259
Rep 295
Drives: 2019 BMW F90 M5 Competition
LOYALTY AUTO GROUP
08-15-2023, 09:17 PM | #88 |
5281
Rep 10,678
Not for me. I can handle this no problem and like the M5. Changed my coolant tank, reduced the heat under it, contained the heat, reflected the heat. Family sedan that does near 140 in the quarter with mods is pretty exceptional.
afo818259.00 |
