03-30-2023, 07:45 PM | #1 |
312
Rep 206
I need some assistance, I'm trying to replace my paddle shifters but I can't seem to figure out how to disconnect this blue connector. Any help will be appreciated. Thanks
03-30-2023, 08:29 PM | #2 |
1133
Rep 2,334
honestly, you don't have to, you can just take off the parts from the back and add the new paddles at the back, that is what i did.
but the blue ones are extremely difficult to remove |
DarkishM5C311.50 |
03-30-2023, 08:54 PM | #4 | |
312
Rep 206
Also, what size is that torx screw holding the steering wheel? |
03-30-2023, 09:03 PM | #5 |
1133
Rep 2,334
i don't remember, but in this video i believe he will say all the sizes and i know he's a member here too
https://youtu.be/t0ObPgcpOiE |
03-30-2023, 09:11 PM | #6 |
312
Rep 206
[QUOTE=armoredsaint;29987842]i don't remember, but in this video i believe he will say all the sizes and i know he's a member here too
I seen that video, thanks. Your car is a MY23 correct? The reason I ask is because my car doesn't have the regular bolt holding the steering wheel like the other F90's in all the videos. My car actually has a torx bolt. Did yours have a torx bolt as well? |
03-30-2023, 09:26 PM | #7 |
1133
Rep 2,334
it was made in Nov 2021 for MY2022 iirc and it's just a bolt, yeah i noticed that earlier too, and had to do a double take on your pic
DarkishM5C311.50 |
03-30-2023, 09:54 PM | #8 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
Top part where smaller blue connector connects to bigger blue connecter u can use a tiny flat had and try to pry it a bit. I have changed a lot of paddles and it always came off as u have to pry it a bit. Even if any clip breaks it doesn’t matter much as it will still sit tight once plugged in again.
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
DarkishM5C311.50 |
03-30-2023, 10:03 PM | #9 | |
312
Rep 206
03-31-2023, 06:51 AM | #11 |
312
Rep 206
04-04-2023, 11:47 AM | #12 |
312
Rep 206
Update: After studying the connector a bit more, there's a small hole where you can see a little notch. I inserted a really small flathead screwdriver and pushed up while holding the connector and the connector came appart easy. See attached pictures. Hopefully this helps anyone else trying to swap out their paddle shifters.
I love the carbon fiber look of the shifters and they make it a lot easier to reach. Once I get the torx bit, I will be able to install the rest of my steering wheel carbon trim. |
04-05-2023, 09:54 AM | #13 |
95
Rep 132
Nice! Yeah those connectors are a massive pain.
DarkishM5C311.50 |
05-02-2024, 03:58 PM | #14 |
13
Rep 69
Sorry to revive an old thread but hoping yall might know...
I broke my blue connector as pictured in this thread when swapping back to my OEM shift paddles. Anyone know the part number? Thought it was 8373579 since it's printed on it, but it's not clear and can't find it on bmw part stores. I bought these off amazon because they came up and appear to be the right connection... https://www.amazon.com/NuIth-Speaker...cx_mr_hp_atf_m any insight greatly appreciated! |
05-13-2024, 10:27 PM | #15 | |
13
Rep 69
johnny5ive31.00 |
