BMW M5 F90 (2018+) General Forums F90 M5 vs...    Car and Driver Compares F90 M5 Against AMG E63S, CTS-V, Panamera Turbo
      03-20-2018, 08:43 PM   #45
MTHX
MTHX's Avatar
233
Drives: 335XI MPerformance edition
2018 F90M5  [0.00]
Originally Posted by vtknight View Post
This is the point I am trying to make. NA cars and FI cars are already night and day in terms of how theY are affected by octane. But the latest FI cars are highly sensitive as they are tuned for more boost and timing to make the power outputs we see today (and requisite performance). They are tuned for optimal performance on 93. The GTR is an excellent example as Motortrend tested the car many times in Cali and the results were so poor they started to add octane booster (to the Porsche's as well). For those trying to save money on fuel - I suggest not being these FI cars as you won't get the performance they are capable of. As to "evidence" - I would suggest asking any experienced Tuner who builds quick and fast cars. I have been racing for 30 years - and this is a very well known, basic concept. All of my cars tuned for street on 93 would ping if I got into boost on 91 - even with ECU adjustment. It's a big difference with the more powerful/higher boost FI cars. That said - if you are getting a new F90 M5 and don't think it's an issue - it is your car.
the problem is not the money, it’s more the ability to put some good 93 octane fuel on the car.
there, (in canada) we have petro canada that has a 94 octace, but with 15% ethanol mixture ...
if i compare from shell, they have a better 91 octane fuel than petro-canada 91. (probably the quality of aditive)
bmw need to provide some certified octane booster lol
E60 550 2007 - Grey //
F30 2015 335XI MPerformance edition - Lacuna Seca Blue //
F30 2015 335XI MPerformance edition - Grey black //
F90 2018 M5 - Donington Grey
vtknight966.50
      03-20-2018, 09:38 PM   #46
frankchn
288
Drives: F90 M5
As to "evidence" - I would suggest asking any experienced Tuner who builds quick and fast cars. I have been racing for 30 years - and this is a very well known, basic concept. All of my cars tuned for street on 93 would ping if I got into boost on 91 - even with ECU adjustment. It's a big difference with the more powerful/higher boost FI cars. That said - if you are getting a new F90 M5 and don't think it's an issue - it is your car to test that theory with.
If an engine is rated for a certain performance with 93 octane gas, then running a 91 octane fuel through the system will be detrimental to performance.
Tuned engines do run boost at much higher than most manufacturers, so naturally they would be more susceptible to fuel quality issues. The engine themselves might not be able to retard timings enough to compensate for poorer octane ratings if they are running with extra boost.
That said, I think if BMW specifies that the minimum requirement to run the S63 engine is 91 octane, then using 91 octane gas is fine, even if the engine is not performing at the same rated horsepower as when using 93 octane gas.
I've not heard of any issues with knocking due to people putting in 91 gas rather than 93 gas in stock S63 engines, and I think that holds true for the new revision of the engine in the F90 M5 as well. Of course, if you tune, everything goes out the window.
      03-20-2018, 09:39 PM   #47
frankchn
288
Drives: F90 M5
There is a gas station selling 100 octane near my place, so I plan to mix 91 and 100 to get 93 if I am going to push the car etc....
MTHX233.00
      03-20-2018, 10:09 PM   #48
vtknight
vtknight's Avatar
967
Drives: 2019 F90 M5 Competition
I think your mind is made up - which is fine. I did not say the car will knock on 91. I am saying the performance will be significantly degraded. For example - you will not go 10.9 at 129 MPH on 91 octane. Maybe an 11.4 or 11.5 at 122-123 MPH. If that isn't an issue for you - then all is well.
frankchn287.50
      03-20-2018, 10:13 PM   #49
frankchn
288
Drives: F90 M5
Definitely, I do expect a degradation in performance when running on pure 91.
(I don't expect the engine to break though )
      03-20-2018, 10:17 PM   #50
vtknight
vtknight's Avatar
967
I'm in Toronto - so I understand. Two things from my point of view: ethanol is not a bad thing, at all. That said - with any additive - consistency will be an issue versus raw octane. Ethanol is literally used in almost every bigger power race application today. The car I use for drags is on E98. E98 allows me to push the tune on my car past what C16 or Q16 allows (although C16 and Q16 are both higher octane fuels). Ethanols "trick" is it both cools the engine, but requires a ton more fuel (about 40+% depending on the tune and car). By providing more fuel to burn and keeping the temps down - timing and boost can be increased. It is not a street fuel - despite being available in the US quite plentifully (at least at the E85 and lesser levels - though some do have "E100") - again - due to very poor mileage. I consume almost 3 gallons of fuel in one 1/4 mile pass (due to 3300 CC's of injector).
So for pump fuel tunes - 94 octane is where it is at - although I have found some Esso 93's to work well with my other cars. Jury is still out as they have some serious negative press.
My M5 will only be on 93 or greater octane as I want the performance I purchased - all the time.
MTHX233.00
      03-20-2018, 10:19 PM   #51
frankchn
288
Drives: F90 M5
I would totally get 93 if only it were actually available in California
vtknight966.50
      03-20-2018, 10:40 PM   #52
vtknight
vtknight's Avatar
967
And I get that - and that does suck. The magazine test where they had to add octane booster was in Cali. All you can do is what you stated above - mix with 100 and pray for a higher overall number. If you have enough - you could get almost 96 lol.
frankchn287.50
      03-21-2018, 02:12 AM   #53
Stealth7
147
Drives: No BMWs Right Now!
So if the M5 has to run 91 in CA with degraded performance and the E63s is designed for 91 and has full performance ... . The real question is what octane fuel was in the M5 for the test?
      03-21-2018, 09:54 AM   #54
vtknight
vtknight's Avatar
967
I personally cannot believe the E63S was designed for 91. That said - I will read the article and see if it is mentioned.
EDIT: Fuel used was not mentioned. The test was in Cali.
      03-21-2018, 02:52 PM   #55
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
Impressive showing, especially since C&D hasn't been kind to BMW or M lately. Back to the future then - circa 2000!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
      03-21-2018, 05:51 PM   #56
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
Originally Posted by esquire View Post
Good result. But I don't understand how they give the m5 and the e63s the same marks in the quarter mile , when the m5 has been measured with a faster quarter mile. Someone explain that to me.
the M5 has a faster quarter mile as measured by WHOM? Car and Driver does their OWN tests and measurements.
https://www.caranddriver.com/feature...-c-d-test-cars
      03-21-2018, 05:54 PM   #57
M3 Adjuster
Albania
7906
Originally Posted by dhirm5 View Post
C&D back to loving the M5 -- I guess BMW decided to start paying again...
J/K but if someone happens to be on the inside, it sure feels that way. For a while Audi won every comparo.. speaking of which, where is the RS7 in this test?
out to pasture...
      03-21-2018, 05:58 PM   #58
Richy Rich
Richy Rich's Avatar
Drives: F80 | MKIV Supra | Aventador S
I'd still take the new Panamera over all of them.
      03-21-2018, 06:10 PM   #59
Teutonic
Teutonic's Avatar
2709
Drives: BMW
Logical, the M5 is the best choice in here anyway.
And of course it's a winner. Any doubts?
      03-21-2018, 06:13 PM   #60
AudiA4
AudiA4's Avatar
648
Drives: 2022 G01 X3 M40i (Black/Black)
Originally Posted by shahin View Post
The biggest joke is they gave more points to Cadilack over Porsche
Not Bias at all
The CTS dominated in chassis development and the fun to drive category, and for $75,000 LESS than the Porsche (the cost of an additional M3!)...so why do you find this surprising?
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust
2006 E90 330i (Silver) 6MT, Sport
Appreciate 3
vtknight966.50
6ixSpd6014.50
swanson733.00
      03-21-2018, 06:23 PM   #61
vtknight
vtknight's Avatar
967
I like the fact CD uses Race Logic boxes - I'm not sure if all the other Mag's do (or what equipment they use) - but it is sophisticated enough to give fairly reliable results. As Road and Track ran the exact same 0-60 and 1/4 ET, but with a 127 MPH trap - it is showing the results are consistent over different testing days, tracks and drivers.
Either way you slice it - this F90 M5 is quicker and faster than any stock R35 GTR from the factory - including the NISMO. It also ties the GM provided C7 Z06 0-60 and 1/4 mile times. That is a crazy fact for a four door, 16 foot, 4300+ lb luxury GT car.
      03-21-2018, 06:35 PM   #62
raysspl
raysspl's Avatar
992
Drives: walking, bicycle, & bus
Always glad to see BMWs taking 1st place
re
Appreciate 3
      03-21-2018, 06:52 PM   #63
Brake_Late
Brake_Late's Avatar
Norway
1938
Drives: 2015 F82 M4 FIREORANGE2
Originally Posted by DallasLife345M View Post
Winning
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams,
CarbonStrucktureAnthracite, CF_Everything
BMWPhotoVin, 01of01, GTS DCT, EPS, MDM,
CS EDC,Analog Dip ,GTS parts.
Euro Vin e30 M3, FIA cage / 14.7 p / w ratio.
Euro E30 touring G30 MSport i3s LBB X5M
3.2carrera
https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA
      03-21-2018, 06:55 PM   #64
Brake_Late
Brake_Late's Avatar
Norway
1938
I know I couldn't take my eyes of this one yesterday... even standing still !
3.2carrera
Vervain397.50
      03-21-2018, 07:05 PM   #65
IANNUZZI
31
Drives: 2016 GoDZilla
No, the F90 M5 is limited to 163mph so it is not faster than any stock GTR which achieves 190+
No, the F90 M5 is not quicker than any stock GTR 0-60mph, a stock GTR can go as low as 2.7. They can also go as low as 2.6 on 335s
2012 Nissan GT-R Premium 530 448 2.9 11.2 122.7 101 1.05 23.3 sec @ 0.89 g
2013 Nissan GT-R Black Edition 545 463 2.8 11.1 124.8 105 1.03 23.0 sec @ 0.91 g
2014 Nissan GT-R Track Edition 545 463 2.7 11 125.1 94 1.04 23.0 sec @ 0.93 g
2015 Nissan GT-R NISMO 600 481 2.9 11 126.6 97 1.06 22.9 sec @ 0.91 g
2016 Nissan GT-R 45th Anniversary 545 463 2.9 11.2 122.0 103 1.0 23.5 sec @ 0.90 g
      03-21-2018, 07:22 PM   #66
DS_BMW
DS_BMW's Avatar
1603
Drives: 2022 M4 comp, 22 M240
0-100 in 6.6!
