03-05-2024, 05:16 PM | #1 |
1652
Rep 2,402
Will dealers patch tires or no?
Will a dealer patch a tire or do they always insist on replacement for liability reasons? I’m talking about an easily patchable tire with the screw in the middle of the tread.
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
03-05-2024, 05:45 PM | #2 |
2273
Rep 3,299
Replace IN PAIRS. There is money to be made.
Learn how to plug them yourself. It's pretty easy and very reliable. Mike
03-05-2024, 05:56 PM | #3 |
21
Rep 30
My dealer in Las Vegas won't patch tires. Pep Boys will do it even if you already have 2 patches in a tire :-)
03-05-2024, 07:03 PM | #4 |
222
Rep 104
I am in a similar situation with one of my rear summer Pirellis with only 5K miles on it. It’s patchable but Costco declined to patch it, saying that the tire manufacturer and BMW instruct them not to patch these tires as they will lose speed rating.
Since this happened right around the time when I switch to all seasons for winter, I made the switch instead of dealing with it. Now debating if I should get it patched or just switch to PS4S |
03-05-2024, 07:18 PM | #5 |
4094
Rep 3,675
Drives: 2022 M5C
I’ve had half a dozen patches (proper patches, not plugs) over the last few years and two F90s, exactly as you describe, usually while waiting for a replacement tire to come in. Both branches of my local dealership have done them each time. On one occurrence, I had a hesitant tech, but I insisted to the service manager that it be done, and it was.
Not a BMW guy...but certainly an M5 guy.
03-05-2024, 07:20 PM | #6 |
4094
Rep 3,675
Drives: 2022 M5C
Worth noting that somewhere like Pep Boys is generally plugging, not patching. Obviously a plug is not a proper patch.
03-05-2024, 07:29 PM | #7 | |
316
Rep 396
Drives: 23 M5C, 19 X5
logicators222.00 |
03-05-2024, 07:54 PM | #8 |
1652
Rep 2,402
It’s not about whether I should get it patched….I’m definitely getting one. It’s just a matter of whether the dealer will do it or I need to take elsewhere. Sounds like I need to take to tire shop….
03-06-2024, 05:12 AM | #9 |
158
Rep 308
To keep your speed rating you should get a proper vulcanised repair. My tyre repair guys will keep the tyre for a day or two. They cut out the punctured area and rebond the layers back in using a special machine/jig that applies heat. Then they smelt rubber back on the tread and recut the pattern. Even sidewall damage up to a certain size can be repaired this way. Costs about £30 but cheaper than a new tyre that's £300
MarcoF9021.00 |
03-06-2024, 02:20 PM | #10 |
2594
Rep 2,683
Drives: '24 X7 M60i
My local dealer stopped repairing tires several years ago saying it is due to liability issues. So I usually just go to Discount Tire for repair.
Ex Stig
'25 M5 Touring (on the list, first slot) '24 X7 M60i '22 M5 CS - (sold) |
03-06-2024, 03:45 PM | #11 |
2273
Rep 3,299
I've plug many tires. My RS6 twice, Porsche TWICE, M5 Once, Sienna once, second sienna once, Q7 once, civic twice, Avalon once, Subaru WRX once, Several Friends cars. NEVER HAVE HAD AN ISSUE. Plugged several tires on my tractor too.
They work, they are safe. Patches maybe "Better" But how much better I don't know. Mike
carseatsm5837.50 |
03-06-2024, 04:15 PM | #12 | |
222
Rep 104
In all seriousness, I was told that a patched tire can simply burst at very high speeds. |
03-07-2024, 06:02 AM | #13 |
2273
Rep 3,299
Yes, we've all been told that. Your dealer, who has a stock of new tires close by, will certainly tell you that. You'll get into the differential discussion and tire diameter differences. I am not sure what there Differential is for any more.
Interestingly enough, or local Subaru dealer (son's experience) has a machine to WEAR DOWN the new tire to match the older one. Now that is interesting. Maybe something to that differential thing? Who knows. You know what else can happen at high speeds? 1. A New Nail or chunk of metal can impale your tire just as you 'crush' that Vette 2. A Deer can jump out in front of you (several friends) 3. A chunk of steel can impale your roof (son's Girlfriends car on highway) 4. Large Rock can be dropped from overpass (reported many times by jackasses) 5. You can spill your coffee at high speed (not me LOL) 6. A control arm can give out (any given Chevy or Ford) 7. A wheel can go flying off because the 'dealer tech' failed to torque the lugs (my brother - car salesman at the time and a friend who is a cop - same dealership) 8. Sudden Low Oil Light because debris took out oil cooler 9. TWO nails at the same time, probably common on the Mass Pike at Rush hour LOL. 10. Etc Etc. Plugs are fine. You have to assess the size of the hole and the location. On sidewall, not a good choice. On a near bald tire, not a good idea, Hole from a 1/2 bolt, probably not a good idea. If they were not safe, would they still be sold? Mike
03-07-2024, 09:07 AM | #14 |
316
Rep 396
I've used the "temporary" licorice plugs on every car I've owned. They either leaked right away because I didn't get them in all the way, or they lasted until the tire wore out. I wouldn't track a plugged tire, but for street driving if the plug pops out your tire is just going to deflate fairly fast. Since you aren't going faster than ~80, this doesn't seem too bad and you should be able to pull over and stop. The tire won't blow up. After I plug I check the tire pressure every day (after doing a soap test) and keep an eye on it until it has gotten enough heat cycles and worn down and seems stable.
If a newish tire got a puncture, I might take it in to get a patch (which is put on from the inside). |
03-13-2024, 11:50 PM | #16 |
2337
Rep 2,029
Drives: INDIVIDUAL F90 M5C LCI
I’ve plugged 3 tires w my BBS wheels.
One need a patch. If you don’t track- you shouldn’t care.
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
03-14-2024, 12:23 PM | #17 |
699
Rep 598
I am trying to understand why would one in their right mind go to the dealer for such service ? I own 08 E60 550i that had some slight issues shifting. I called BMW dealer few weeks ago asked them if they will service valve body or just take it out and send to the automatic transmission shop to have it serviced. No I was told. This is a liability and they will not do that. All they can do is to remove it and installed new one. So in simple words.
We are service shop but we will not repair your car cause it’s liability. Imagine calling let’s say roofing company asking about roof repair and they will go like sorry sir. We will not replace your shingles because of liability reasons, but will gladly get the whole roof removed and rebuilt. This becomes f*****g mad world. It all because of suing culture we have here. |
03-14-2024, 02:38 PM | #18 | |
4094
Rep 3,675
Drives: 2022 M5C
Roofers do exactly that all the time, for the exact reasons you mention.
03-14-2024, 02:43 PM | #19 |
699
Rep 598
Ha ha I know I meant the whole structure including rough carpentry anyway why don’t we start replacing cars when oil change is needed. There’s quite liability when it’s not properly done. Damn. I just gave an idea….
03-14-2024, 04:24 PM | #20 |
222
Rep 104
Not a novel idea at all. Tesla is practicing it already. A friend recently bumped his brand new model 3 into a boulder on the side of the road because of fog, and thought it was a very minor damage and should be quickly repaired. Insurance totaled the car because Tesla said it will take them 6 months to fix it because some parts needs to arrive from overseas 😂
03-14-2024, 04:27 PM | #21 | |
699
Rep 598
logicators222.00 |
03-14-2024, 07:58 PM | #22 |
106
Rep 180
There are dealers that use mobile tire repair service, this way the liability is on the vendor/supplier. Regarding roofing full tear off is needed to keep the warranty of the shingles and the labor warranty of course. No overlays!
