07-15-2022, 07:56 PM | #68 |
1543
Rep 2,021
06-18-2023, 12:23 PM | #70 |
41
Rep 52
Great thread!
By chance anyone know the part number to that (plastic round) oil drain plug access cover?
2019 BMW M5
2016 Dodge Charger HC 2005 E55 AMG Wagon |
06-18-2023, 12:28 PM | #71 |
5281
Rep 10,678
Does anyone have a round plastic cover over both the drain plug and the oil filter housing? My car has one over only the drain plug. For PN, check realoem under body or chassis and find the stiffening plate.
06-18-2023, 01:40 PM | #72 | |
2277
Rep 3,304
Mike
07-05-2023, 10:20 AM | #75 |
75
Rep 68
My first oil change is complete!
A few observations: 1. As others report, the stock oil filter canister burps out oil upon removal. I replaced it with a Weistech canister, swapping over the springy clip at the bottom of the stock unit. 2. You cannot reset the oil change interval if you also have a low fuel indicator. The fuel warning pops up before you can hold in the button for ten seconds, negating the effort. Once I added fuel, easy peasy. 3. The original owner left me a present at the bottom of the engine bay…. A shorty flat head screwdriver wedged in a plastic cover. It was where the arrow is, and I removed the 8mm head screw (circle) to get it out. 4. I had to build a 3 ft ramp to get the car up on my metal ramps. An 8ft 2x12 cut down, double stacked with angled approaches worked fine. I put the car in 2WD when approaching to avoid shooting the ramp out. |
07-18-2023, 05:36 AM | #77 |
62
Rep 99
How much oil is from the min-max levels?
I know on conventional dipsticks is 1qt of oil from marked min all the way to top off at max mark. I just want to know how to guesstimate oil add when it comes down to that. |
07-19-2023, 04:44 AM | #78 |
335
Rep 411
Drives: 23 M5C, 19 X5
I think it is 1L. It does not detect overfilled. So when I do my wife's X5 I add 1L less than it says, start the car and measure and fill as needed. I plan to do the M5 the same way.
07-21-2023, 09:04 PM | #80 |
4151
Rep 7,165
Drives: F90 M5 / F15 50i
Wouldn’t expect to be adding oil like the X5. Night and day between the two N63 engines so far for me. And haven’t seen anyone mention having to add oil like we have to in the X5 side of the garage.
'07 Yamaha R1 (sold)
GTTC62.00 |
08-13-2023, 07:40 PM | #82 |
848
Rep 483
Pardon but is this kit good to change the oil out? I wasn’t easily finding one on FCP Euro though I’ve seen people recommend going there, too. I tried to read the entire “what oil do you use” thread and my brain shut down.
https://www.ecstuning.com/b-genuine-...83212365946kt/ |
08-13-2023, 09:30 PM | #83 | |
1839
Rep 1,328
Yesh in general oil threads are a waste of time. For the most part, if you can buy it over the shelf, if it's any where near CLOSE to what the "optimum" spec of your engine is, you're going to be fine. The real "optimum" spec varies car to car and climate to climate, so don't sweat it. Unless you are tracking or racing the car, use close to the BMW spec and stick to it. Shawn |
carseatsm5848.00 |
09-11-2023, 10:33 PM | #84 |
222
Rep 320
Quick question as I have searched and not found the answer to this question.
What size wrench/socket do I need to remove the new style oil filter housing? This is for the one with the drain plug in it. |
09-12-2023, 10:33 PM | #85 |
69
Rep 92
36mm socket. Make sure you get the correct oil filter kit, it comes with a new drain plug. Many people think that you can just swap the o-ring but that is not the correct wayZ
10-29-2023, 08:23 PM | #87 | |
345
Rep 233
Drives: F90 M5 LCI - Aventurine Red
Thanks for the great write up with photos and strong detail. I would like to ask you if you can kindly reconfirm if the Torque Specs for the oil sump plug and oil filter housing are 25 NM (18 Lb.Ft). I think you mentioned later on in the thread that it may have been 7.5 Lb.Ft. or so, if I remember correctly? I'll be doing an interim oil service soon and wanted to double check these torque specs. Thanks
F90 M5 LCI - Aventurine Red/Smoked White-E39 M5 - Modified ESS Supercharger Kit -E34 M5 1995 - Arctic Silver / Black Leather-
E30 M3 1987 - Diamond Black Metallic / Black Leather-996 Turbo - Lapis Blue/Savannah-VW Rallye Golf |
10-30-2023, 09:13 PM | #88 | |
2277
Rep 3,304
Both drain plug and the oil filter housing are torqued to 40 nm. Sounds high to me. 29 Ft Pounds. The filter housing of that high sounds odd...but that is what the manual says. Maybe someone else can chime in..... Mike
M5 London344.50 |
