BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Only lower the front?
      02-21-2024, 11:54 PM   #1
S EyeLand
167
Drives: F90 M5C
Hi all,
I'm satisfied with the rear height, the front it about an inch to high imo. Is it a crazy idea to only install the M550i springs in the front and leave the rear stock? I think a drop in the rear would be too much and start to look a little tacky.
      03-03-2024, 09:28 PM   #2
chorizotaco
chorizotaco's Avatar
Drives: BMW M5
I'm interested in this too. I feel like my rear is pretty good but the front could use a slight drop.
      03-03-2024, 09:40 PM   #3
S EyeLand
167
Drives: F90 M5C
[QUOTE=chorizotaco;30955199]I'm interested in this too. I feel like my rear is pretty good but the front could use a slight drop.
I installed the fronts today. Car drives absolutly mint, I'll post pics tomorrow. The job was awful I regret not waiting for a shop to install them.
      03-06-2024, 08:26 PM   #4
M5KEITH
M5KEITH's Avatar
130
Drives: M5
If u lower your car with M550i springs and keep your rears OEM it will throw off your car’s suspension in a negative way in the corners when driving aggressively. Soft in front in stiff in the back is not ideal.
      03-06-2024, 08:31 PM   #5
M5KEITH
M5KEITH's Avatar
130
Drives: M5
I’m lowered on M550i all round and car is not as stiff and solid cornering.
If I could do it again I would have went with M5 H&R springs. All pictures of springs on line are right after install but spring settle another 1/4 of inch making M550i spring very aggressive.
      03-06-2024, 09:20 PM   #6
S EyeLand
167
Drives: F90 M5C
I think i may be rubbing in the front on the m550i springs.
      03-07-2024, 02:32 AM   #7
Silverx88x
Drives: 2019 M5 Competition
what size spacer you using on the front? how long did it take you to install just the front springs?
car looks great with the satin wrap!
      03-07-2024, 09:28 AM   #8
S EyeLand
167
Drives: F90 M5C
13.5mm from ECS. It's difficult to get the assembly in and out of the wheel well. You'll do much better if you have 2 strong guys. One to push the lower assembly down and the other to clear the top of the strut. Otherwise, it was easy and took about 2 hours per corner because I spent a while fighting with getting the strut out and back in.
      03-07-2024, 11:52 AM   #9
pbonsalb
5288
You are fighting the swaybar; undoing one end link helps.
      03-07-2024, 12:42 PM   #10
S EyeLand
167
Drives: F90 M5C
Yea i removed the upper sway end link, it was the axel that was in the way. The strut fork bottoms out on that. It's impossible to separate the strut from the fork while in there too, I tried a spreader and silicone spray... just isn't enough room. If you remove the axle it would be a 30 min job each corner and save the axle boot as well.
Edit, maybe i should have compressed the spring?
