12-27-2023, 12:23 PM | #1 |
381
Rep 319
SpeedProtocol (Droner) F90 M5 Build Thread
I'm starting this build thread for my new F90 M5.
About the car: 2021 M5. 13k miles. Motegi Red -Driver assistance package -Executive package -Comp package. -B&W stereo. -Steel brakes. Instagram : https://www.instagram.com/speedprotocol/ F10 M5 Build I've had the car several days and mods ordered so far: -H&R M550i springs -IND side marker delete -15F/12R spacers -Floating center caps Much more to come.
-=SpeedProtocol=- 2014 M5 Sakhir Orange- BPM Stage 1 - Soul Performance Exhaust - PG Intakes - CarboTech 1521 Pads - Turner Monoballs 2021 M5 Motegi Red- Stock Last edited by SpeedProtocol; 12-27-2023 at 12:33 PM.. |
12-27-2023, 04:43 PM | #2 |
22
Rep 83
Very nice spec! Exhaust next
SpeedProtocol381.00 |
12-29-2023, 03:22 PM | #3 |
381
Rep 319
-=SpeedProtocol=- 2014 M5 Sakhir Orange- BPM Stage 1 - Soul Performance Exhaust - PG Intakes - CarboTech 1521 Pads - Turner Monoballs 2021 M5 Motegi Red- Stock |
12-30-2023, 11:05 AM | #5 |
381
Rep 319
I used to have a black 98 trans am. I used to drool over the sunset orange metallic ones. Guess im making up for what I couldn't have before lmao.
Desking101151.00 Blaxwil652.50 |
02-12-2024, 12:10 PM | #6 |
381
Rep 319
I acquired a Meisterschaft GTHaus SGT exhaust with the LMR midpipes.
They took away the center jackpoint on the f90. I had to come up with a way to get the car in the air. I made a set of car stands. They are stackable so I can put the car up higher in a series of steps. Small one, then the bigger one, then both of them together. This way I didn't have to jack the car up extremely uneven(dont want any new rattles or creaking). These worked out very well but they took me a few days to make.
02-12-2024, 12:14 PM | #7 |
381
Rep 319
The stock exhaust removal was a bit challenging solo. I got creative and I was able to drop it down and drag it out by supporting it with a ramp/wood on one side and my jack on the other side.
Justao399.00 |
02-12-2024, 12:23 PM | #8 |
381
Rep 319
Installation was a bit time consuming to get right. I had to adjust it alot. You start from the downpipes and work your way back, leaving everything loose at first. And then start from the front and tighten clamps and hangers as you go.
Pro tip: support the X-pipe with a jack a tad bit higher than where it will naturally hang. Tighten everything up while its supported, front to back. This will help take the slack out of the exhaust and make it easier to position and more rigid. I added a couple washers under the tunnel brace because the midpipes were barely touching. Problem solved.
-=SpeedProtocol=- 2014 M5 Sakhir Orange- BPM Stage 1 - Soul Performance Exhaust - PG Intakes - CarboTech 1521 Pads - Turner Monoballs 2021 M5 Motegi Red- Stock Last edited by SpeedProtocol; 02-12-2024 at 01:05 PM.. |
ny2nj192.50 |
02-12-2024, 12:59 PM | #9 |
381
Rep 319
And here are the mandatory video clips:
Cold Start - https://youtube.com/shorts/NEE1CmX23...l1MA4l_Xr0zZ8a Revs - https://youtube.com/shorts/JvDJiE40n...hykyW7E1fUbSAE More Revs - https://youtube.com/shorts/gQXHoTw2B...P-CP-ehA7o7UWS
02-12-2024, 06:25 PM | #11 |
381
Rep 319
I did the little muffler. Not sure how much of a difference the straight pipe would make. Ill probably do downpipes in the future so I figured the quieter option would be better.
