10-03-2022, 09:41 AM | #1189 | |
Be Present
269
Rep 74
The H&R ‘550i has a progressive spring rate that matches the stock M5 comp/CS spring rate in a shorter package. Literally the only effect of install is that the car is lower, thus lowering the center of gravity, and theoretically improving aerodynamics and body roll. |
10-03-2022, 10:03 AM | #1190 | |
1887
Rep 2,400
10-03-2022, 12:37 PM | #1191 | ||
1839
Rep 1,328
The CS is pretty much perfect suspension setup for a heavy four door sedan on track. A square setup makes a little bit of oversteer possible. But otherwise, unless you're just into looks, don't mess with it. It's as close to as good as it gets for this weight/power class. Shawn |
10-03-2022, 12:56 PM | #1192 | |
551
Rep 638
Pretty much. CS will never see the track, did suspension for looks. And it looks MUCH better with the drop. |
Littierally268.50 shawnhayes1838.50 |
10-03-2022, 01:56 PM | #1193 | |
Be Present
269
Rep 74
BMW’s goal was not to build a purpose-built track car with the CS, idk why everyone thinks it is. They allowed some features to slant away from comfort and toward performance - but not the suspension. Struts and springs are unchanged from the LCI M5C and M8C - with a happy balance of performance and comfort. If performance is all you’re worried about, the suspension could be improved at the sacrifice of comfort. |
10-03-2022, 04:47 PM | #1194 | |
1839
Rep 1,328
But to each his own. The car is absolutely KILLER on track, and embarrasses many dedicated track cars, and most lower priced Porsches. But hey, if THIS is your game, why not? Shawn |
10-03-2022, 05:51 PM | #1196 | |
1839
Rep 1,328
But to say that BMW gave "some" nods to performance with that many changes (it got rid of the front camera and the center console, for goodness sakes) and not know that's a barn burner to make good stats is just denying how much work they did to remove a fair amount of weight. We're all different, and that's fine. But to poo poo the idea that this a a track capable car and looks are more important is also kind of silly. Shawn |
Littierally268.50 |
10-03-2022, 09:59 PM | #1198 |
1839
Rep 1,328
Length, height, width, or weight?
Porsche 911 Turbo S Wheelbase : 96.46 inches / 245.0 cm Length : 177.44 inches / 450.7 cm Width : 74.02 inches / 188.0 cm Height : 51.06 inches / 129.7 cm Front Axle : 60.67 inches / 154.1 cm Rear Axle : 62.6 inches / 159.0 cm Num. of Seats : 4 Aerodynamic drag coefficient - Cx : - Front Brakes - Disc dimensions : - (16.14 inches / 410 mm) Rear Brakes - Dics dimensions : - (15.35 inches / 390 mm) Front Tyres - Rims dimensions : 245/35 R20 Rear Tyres - Rims dimensions : 305/30 R20 Front Wheels Width : 9,0" Rear Wheels Width : 11,5" Curb Weight : 3693 lbs / 1675 Kg BMW M5 CS Wheelbase : 117.4 inches / 298.2 cm Length : 196.89 inches / 500.1 cm Width : 74.92 inches / 190.3 cm Height : 57.8 inches / 146.8 cm Front Axle : 63.98 inches / 162.5 cm Rear Axle : 62.76 inches / 159.4 cm Ground clearance : 4.69 inches / 11.9 cm Num. of Seats : 4 Aerodynamic drag coefficient - Cx : - Front Brakes - Disc dimensions : Vented Discs (- inches / - mm) Rear Brakes - Dics dimensions : Vented Discs (- inches / - mm) Front Tyres - Rims dimensions : 275/35 R20 Rear Tyres - Rims dimensions : 285/35 R20 Turning radius : 41.3 feet / 12.6 m Curb Weight : 3968 lbs / 1800 Kg Source:ultimatespecs.com It's a whole different world. Hard to say if the "sportscars" have gotten fat, or the "family cars" have stayed static while everything else has gotten fat. Shawn |
10-04-2022, 06:59 AM | #1199 | |
876
Rep 1,319
10-04-2022, 08:30 AM | #1200 | |
983
Rep 1,801
10-04-2022, 10:35 AM | #1201 |
1716
Rep 1,913
Drives: 2023 M5C
The CS badge on the back says so. The badge gives it the handling.
IG @windtendo_m5
Littierally268.50 |
10-04-2022, 11:56 AM | #1202 |
224
Rep 211
Thought I would share some pics of my car from last weekends BMW car show in Boston!
10
Littierally268.50 HulkM5cs215.50 shawnhayes1838.50 ResIpsaLoquitur4135.00 clutchdj1886.50 Ominous136.50 Simon H876.00 bigfra128.50 KB7120.00 race_condition36.00 |
10-04-2022, 12:51 PM | #1203 | |
1839
Rep 1,328
Shawn |
10-04-2022, 12:53 PM | #1204 | |
1839
Rep 1,328
Shawn |
10-04-2022, 12:56 PM | #1205 |
1839
Rep 1,328
10-04-2022, 01:00 PM | #1206 | |
1716
Rep 1,913
Drives: 2023 M5C
"Chief among which is the addition of a brand-new set of dampers; BMW says the new M5 Comp “benefits from experience gained in the development of the new BMW M8 Competition Gran Coupe”." https://www.topgear.com/car-news/fir...cy-new-dampers The M5 LCI and M8 share the same suspension.
IG @windtendo_m5
Littierally268.50 |
10-04-2022, 01:19 PM | #1207 | |
4135
Rep 3,698
Drives: 2022 M5C
P.S. license plate is awesome! 👊
Not a BMW guy...but certainly an M5 guy.
BMA89223.50 |
10-04-2022, 01:24 PM | #1208 | |
1839
Rep 1,328
"This chassis was adopted to reduce the ride height by around 7 mm. The new Chassis is designed to work with track tires. The suspension system has shock absorbers originally designed for the BMW M8 Gran Coupe. These shocks not only pave the way for a comfortable ride but also reduce tire pressure to improve handling, no matter where you drive. To account for the vehicle’s lower weight and increased tire performance, the front and rear axle bearing springs of the BMW M5 CS have been recalibrated and the damper control has also been revised accordingly." https://www.hotcars.com/bmw-m5-cs-pe...g-enthusiasts/ Everybody who drives a competition and CS back to back say they're different. I haven't done so, but I knew with that much weight, the springs for the Grand Coupe are WAYY wrong for the CS. Shawn |
10-04-2022, 07:11 PM | #1209 | |
551
Rep 638
I think we can all agree cars are heavier, and still doing some very impressive things. The m5 in stock (non cs form) is a great example of that. You are reading too much into me and a few others adding springs to the CS, no matter what you say. We already stated the cars wont be tracked, and yet you still keep badgering "why not" basically. Fortunate enough to have owned a real track car like the 600LT (which is not up for debate) i see 0 reason to track an M5. I'm not saying the CS can't be tracked, it's your car, do as you please. But to say its "made for track use" is a stretch. There are better options out there, if you can afford it. Period. Let's get this thread back on topic, and not about who lowered their CS.. |
Littierally268.50 |
10-04-2022, 10:47 PM | #1210 | |
1839
Rep 1,328
And this IS about the CS. No, I don't care who lowered the CS. Doesn't matter. But, awesome car. I enjoy mine. I even enjoy the pics of the lowered ones (well, not slammed, ruins the look, and the ride as well, but lowered and slammed are different). Shawn |
boost3dx583.50 |
