09-09-2021, 10:14 PM | #1 |
87
Rep 99
Camera Button?
Not sure if this is just how it is designed to work or if I’m doing something wrong. Whenever I press the camera button in the center right below the parking and exhaust valve button the only thing that comes up is the front camera (see attached). Is there no way to change which camera it pulls up? Or to pull up the 3D view? I could have sworn I’ve seen review videos of people showing the 3D view and spinning the car around.
09-10-2021, 12:34 AM | #2 |
///M Specialist South Shore BMW
774
Rep 7,108
You have to use the button with the letter P on it. Not the one with a camera on it. Your using the wide angle front or rear camera. Depends on what gear your in, drive or reverse. Use the button with the P on it. Pdc camera button.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
mike5160.00 |
09-12-2021, 09:02 AM | #3 | |
1913
Rep 4,128
Drives: M235i & G30 540i
Also to get to 360 degree camera you have select it in the menu after you press the P.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
