BMW M5 F90 (2018+) General Forums F90 M5 vs...    1/4 times / Members only
      07-16-2018, 11:32 AM   #23
Imran@Evolve
Imran@Evolve's Avatar
United Kingdom
5386
Drives: All of them
Originally Posted by MTHX View Post
what was the external temp? day run or night run?
Day run and 30 degrees C / 86 f so a hot UK day.
MTHX234.00
      07-16-2018, 01:03 PM   #24
onfireX5
3620
Drives: F90M5,F85X5M
Originally Posted by Imran@Evolve View Post
I did a 11.6 at 126 MPH at the UK track Santa Pod. Launch control would not activate for me either. This was just after the RIS so not sure if it needs some more miles after the 1200?
It’s ready. Did you have DSC off ?
      07-27-2018, 09:12 AM   #25
onfireX5
3620
Not bad for the DA.
vtknight966.50
      08-04-2018, 12:12 PM   #26
onfireX5
3620
Whoooosh !
Appreciate 3
MTHX234.00
vtknight966.50
soooma1380.00
      08-05-2018, 06:15 AM   #27
felixleasing
Drives: 2018 M5
Congrats! Might be the current fastest time!
With the DA where does that actually put you in the 1/4: 10.5-10.6?
Also how safe is it. You mentioned before you weren’t ready for jb4 due to development
      08-05-2018, 08:26 AM   #28
onfireX5
3620
Definitely will be faster at sea level on a 30.x baro and 70f day. More oxygen, more power per psi.
Safety is relative. Betas were going out in May. Too early for me. Then they found out that some M5”s (20 betas our), were setting a code so they added another wire to the ewg harness. And I waited. And no more comments. So I bought, installed and started doing short logs to analyze the data. Finally made an 1/8 mile hit. I’m keeping the target increase at 2psi as atmospheric conditions can effect it slightly. DME is happy. No pulled timing, no throttle closure, iat looks good, AFR looks good,etc. All on pump 93. It’s now locked down on a conservative increase like the RaceChip in my X5M (28,000 milesno issues). I’m not looking for a 6psi increase and +130mph 1/4 mile speeds. Just a nice, smooth increase. It’s probably a 40rwho and 40rwtq bump based on the dyno graph on the JB4 site. Launched correctly, it moves out.
      08-05-2018, 10:26 AM   #29
onfireX5
3620
I am at the Blue Line. Conservative, but plenty for a daily driver.
      08-05-2018, 05:21 PM   #30
felixleasing
Drives: 2018 M5
Makes sense! The problem that I’m having is that I’m not as experienced with logs etc. To the general population it might be a lot of work. Very exciting for the platform
      08-30-2018, 11:14 PM   #31
vtknight
vtknight's Avatar
967
Drives: 2019 F90 M5 Competition
Originally Posted by M5speed View Post
Here's my slip. Apparently I need to go home and practice launch control. I've been reading up on it and its possible I wasn't hitting the gas quickly enough to the floor to get it to kick in.
Another thing I saw about launch control is that the car may be short shifting first to improve acceleration.
Has anyone heard of getting bigger turbos for the M5? I saw an M4 video with some built up turbos. Maybe it'd make a better track car. I tested out an M4 once though and thought it wasn't what I was looking for.
This is a very solid 60', ET and MPH! Any idea what DA you sit at?
      08-31-2018, 11:53 PM   #32
vtknight
vtknight's Avatar
967
Best ET of 10.9 at 127.54 MPH. ~+3000 DA. 90F 94% humidity.
Appreciate 2
MTHX234.00
      10-01-2018, 08:20 AM   #33
vtknight
vtknight's Avatar
967
Keep improving - I will remove the filters next time and use comfort mode for my suspension next time.
Next event should be very solid DA. If we get the prep - I’m hoping we will finally see a 10.8x.
      10-21-2018, 04:26 PM   #34
F01Boost
70
Drives: 2012 750i Msport tuned
Dme stage 2 and Kellerformance down pipe and mid pipe
Slipping in first no LC
2018 F90 stage 2 dme w Keller performance dp
2018 X5m dme tuned
2015 650 vert dme tuned
2012 750i M Sport JB TUNED- Current
2010 135 vert JB Tuned - retired
Appreciate 3
soooma1380.00
      01-25-2019, 12:17 AM   #35
wmurph3
Drives: 535i M sport / S1000RR
2018 BMW M5  [0.00]
2016 BMW S1000RR  [0.00]
How is this setup holding up for you?
      01-28-2019, 11:14 PM   #36
F01Boost
70
All good no issues!
2018 X5m dme tuned
      02-06-2019, 09:15 PM   #37
wmurph3
2018 BMW M5  [0.00]
See anyone doing a different wheel or tire setup for strip? Have you considered it?
      09-22-2019, 07:02 AM   #38
MTHX
MTHX's Avatar
234
Drives: 335XI MPerformance edition
2018 F90M5  [0.00]
Some of my time yesterday.
Stock M5 (non competition)
Gaz : Shell 91 / mix PetroCanada 94 (10%ethanol)
Outside temp : 20c
Tire : Michelin ps
Oiled.change : yes
Gaz tank : 1/2
E60 550 2007 - Grey //
F30 2015 335XI MPerformance edition - Lacuna Seca Blue //
F30 2015 335XI MPerformance edition - Grey black //
F90 2018 M5 - Donington Grey
      09-22-2019, 11:03 PM   #39
vtknight
vtknight's Avatar
967
Great runs! For having a 91/94 mix - these are pretty solid ET's. The MPH is on the lower side - but still solid. I would suggest 94 octane - no mix. Was the track day just a test and tune, limited prep? The reason I ask is because the 60' for Michelins was pretty high for most of your runs. You bring it down to a low 1.7 or high 1.6x and you will see 11.0's.
      09-22-2019, 11:08 PM   #40
vtknight
vtknight's Avatar
967
While I am here I may as well update my timeslip. It was a great track day - okay to solid prep, with an 1800ish DA (if I remember correctly).
It may be hoping for Unicorns, but I do think once we get some really nice, cooler weather (and near zero DA) I may be able to break into the 10.7x range, but I will need that air and a healthy tailwind lol. I haven't yet taken the charcoal filters yet - or touched air pressure - so I have some options to get there. I will try it with no changes first...
      09-23-2019, 08:09 AM   #41
MTHX
MTHX's Avatar
234
2018 F90M5  [0.00]
Yes the track was not prep for real time attack.
The icar track has a reputation of -150 ms. It's a concrete air strip track. (wind and track prep)
l try in october for Napierville.
Do you think that petro canada 94 (with ethanol) is better then shell 91?
My tire pressure was around 36 / 37.
I read in a previous post that you don't floor gaz to activate the LC. You manage to just activate it and floor when light turn green...
I got a lot of wheel spin on LC mode and the car start sliding when i launch at the green light ...
My MPH is not very high too ... probably due to the non sticky strip..
(sorry for my.poor english)
      09-26-2019, 03:28 PM   #42
vtknight
vtknight's Avatar
967
94 octane is definitely superior to 91. No Tuner tunes for 91 (unless you don't have 93 or 94 available).
The ethanol is actually very handy for FI cars (adds cooling and less detonation).
Without prep on concrete - on an airstrip - your 60' will be a challenge.
Finding a good track with prep and you will find much better ET and MPH.
      10-05-2019, 03:36 PM   #43
limeypride
limeypride's Avatar
Drives: 2022 M8 Competition GC
No track data yet so Dragy will have to suffice. These pics are from precisely one of one launches/timed runs I've done in this 2020MY M5 Comp and both numbers beat my 19 M5 after literally 100s. Conditions were pretty good, though, other than potential loss of traction from the cold but my nicely broken in Michelin PS4Ss in 295R/285F decided they didn't care about the $hit road surface or temperature. Note also I had to brake hard in the final second due to a lack of remaining road so there may well have been another 1/10th in there.
- 92 octane pump; no octane booster
- tire pressure @34psi square when cold
- BMC air filter + charcoal delete
- JB4 on map 1
- go-faster black-wrap side skirts and intakes provided an extra -1/10th
- Fisher Price paddle delete saved me an ounce or two
Appreciate 2
MTHX234.00
vtknight966.50
      10-05-2019, 11:21 PM   #44
vtknight
vtknight's Avatar
967
- JB4 on map 1
Wow - 10.60 at only 124.5 MPH? 1.59 60' - nuff said. Almost zero DA lol...awesome!
