03-23-2024, 09:18 PM | #1 |
Rep 4
MHD unlocker
Hello Everyone,
I just purchased MHD unlocker to use with my 2020 m8 competition coupe (DME prior to 6/2020) According to the instructions I’m supposed to use port #1 and #5 the issue I’m facing is on the passenger side DME the connector will fit in port #1 but not #5 and on the driver side DME I’m unable to to fit any of the connectors on any port. I have contacted MHD support and they said I should be able to unlock my car normally and should do both DMEs and that the connectors will fit only in the right ports. So I’ll go and try again and see if I can connect to any 2 ports on both DMEs. But I wanted to check if anyone have ever used the MHD tool on their car and what was their experience. I know this is the M5 forum I have posted the same thing on the m8 forum with no response and I thought I might get some help here Thanks |
05-04-2024, 09:07 PM | #3 |
Rep 4
Yes.
It turns out that the second connector has to be turned around to fit in the DME port. Was able to unlock the DME and tune fine! |
