04-01-2024, 03:38 AM | #1 |
Rep 23
Noisy CCBs
Hi all,
‘19 M5C with carbon ceramics that are noisy. More so when cold but still noisy when warmed up, emitting squeals. Some inconsistency though, I can go out without hearing much at times… and doesn’t appear to correlate to any particular weather condition. Replace pads? |
04-01-2024, 01:08 PM | #2 |
80
Rep 225
I have the same issue with the non-CCB brakes on my '19 M5C.. When it gets noisy, I do a couple of very hard 60-0mph stops on an empty road which eliminates the sound for a week or two. When it starts up again, I repeat the process..
When I have time I'm going to go the route of pulling out the brake pads and applying some new anti-squeak paste to the back of the pads, and then give the caliper a good cleaning. I think part of the problem is that the brakes are so touchy that you rarely have to push the pedal very hard to stop and they glaze over, so not sure if that contributes to the issue. |
gioM5-Comp32.50 |
04-01-2024, 01:52 PM | #3 |
250
Rep 521
My new-to-me F90 made a super annoying squeal at low speeds coming to a stop. I put the summer tires back on this weekend and took the opportunity to see if maybe adding more paste would fix it.
To my surprise, the front pads had zero paste on them. They also looked new. Anyway, I added some paste the the squeal is gone. And while we are at it, yes, they brakes a crazy-touchy! |
04-01-2024, 02:05 PM | #4 | |
359
Rep 429
The only real fix is to brush off the glaze on the pads themselves with sandpaper with very light strokes. Or, do some hard driving/braking and that will burn off the glazing temporarily, but it will inevitably return. A temporary fix I've found is doing some hard braking after getting a car wash or driving in rain -- the water combined with the build up of heat as you do hard braking seems to burn off the glazed layer from the pad. |
04-09-2024, 01:19 PM | #6 |
Rep 23
Thanks peeps. On a road trip this weekend so ample opportunity to brake from speed! Hopefully it will quieten things for a while. I’m mostly driving around town at low speeds (crying shame).
Need to lookup the paste option. |
04-09-2024, 02:11 PM | #7 |
1893
Rep 2,512
I have a 2022 with the CCB's and I have no noise. I do take nice canyon runs a few times a month where I push the car.
2022 F90 M5 Competition & 2019 M2 Competition
2019 F90 M5 Competition 2017 F80 M3 Competition 2014 F10 M5 Competition 2003 E39 M5 |
