BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Fan / cool-down question
      04-05-2021, 09:11 AM   #23
Alberta
Alberta's Avatar
2038
Drives: F90
Originally Posted by GranitM5 View Post
+1. After a spirited or long drive, I park it and let it run for another 10 minutes before shutting her off.
10 minutes seems a lot...
After a drive, I personally let my car run for 3 minutes.
      04-05-2021, 09:45 AM   #24
AHall
982
Drives: 1993 Nissan 240sx
Do you still hear fans after shutting down when your car has run for 3 minutes at idle?
      04-05-2021, 09:50 AM   #25
Alberta
Alberta's Avatar
2038
Drives: F90
Sometimes I do, but it is not systematically the case.
      04-05-2021, 10:33 AM   #26
dawidk1978
dawidk1978's Avatar
Poland
51
Drives: 2021 M8 F93 comp
2017 BMW 540 xi  [0.00]
2021 BMW M8  [0.00]
Originally Posted by Maxlude View Post
Originally Posted by DannyA View Post
If you really rag the bollocks off it you can have the fans spinning for 30mins or more!
Like with ANY turbo car, you should do a bit if a warm down if you've thrashed it.
The S63 engine has auxiliary electric water and oil pumps to cool the turbos even when the engine is not running with the main fan on to expel the heat.
Due to the hot V design the turbos get hotter than traditional outside the bank designs.
10 m idle running = shortage of life v8 engine. V8 engines doesn't like idle running
Gretz
Dawid K
Maverik2594140.00
      04-05-2021, 11:08 AM   #27
Jamesmick
131
Drives: 2018 M5 Azurite Black
Along these lines, years ago I added a Greddy Turbo Timer to a car to which I had added a turbo and a bunch of other mods. Does anything like that still exist and would it address the concerns people have?
I don't usually let mine warm down too much at idle since it takes me a few minutes to squeeze it into my garage. I figure that's enough time to let the oil run through stuff. The car does run the fan afterwards though for a while.
2018 M5 (current)
2012 535i Msport/Dinan (current)
2008 535i Msport (retired)
2003 530i (retired)
2000 C32 AMG (retired)
      04-05-2021, 12:27 PM   #28
GranitM5
GranitM5's Avatar
366
Drives: 2018 BMW M5
Never thought about that but I let the car run for 5-10 minutes on start up to warm up the internals. Don't see it shortening the life of the engine and anyway I don't keep a car that long.
      04-05-2021, 12:29 PM   #29
GranitM5
GranitM5's Avatar
366
Drives: 2018 BMW M5
5-10 minutes give or take.
      04-05-2021, 12:43 PM   #30
FatRear08
FatRear08's Avatar
1427
Drives: F90 M5
95% of the time my fans run on shutdown 5-7 min depending on how hard I drove. I did notice the other day that when I arrived home after a 30 minute drive, which was hard at times, I let it idle in the driveway for about 5 minutes because I had to move some things out of the garage. When I pulled in and shut her off, the fans did not kick on. I’m no scientist but maybe the 5 min at idle cooled it to the point that it saw no need to keep them on???
      04-05-2021, 12:51 PM   #31
Fantastic 5
135
Drives: M5 Comp.
I've heard that you should do that, but who has the time???
      04-05-2021, 01:10 PM   #32
Alberta
Alberta's Avatar
2038
Drives: F90
I doubt it.
An engine running at idle tends to heat more because there's nor air to cool the radiators.
When I was ridding dirt bikes I've learned that the engine was getting cooled while riding at low speeds.
The only reason I let the engine running for 3 minutes after each drive is to keep the turbos lubricated.
      04-05-2021, 01:11 PM   #33
Alberta
Alberta's Avatar
2038
Drives: F90
Letting your engine run 2-3 minutes after a drive is not gonna kill your day!
      04-06-2021, 10:36 AM   #34
Resjudicata
Resjudicata's Avatar
Drives: M850i convertible
Originally Posted by bpma View Post
Even after short, slow rides (quick commutes with kids, etc), once I turn off the engine the engine fan runs noticeably loud, for a few minutes.
Is that normal? I understand it would need it after a highway run, or flooring it a bit, but after a quick, regular commute?
Is that normal?
It's the turbo cooling down. The longer you're in sport mode or reving to push that turbo boost; the longer it will take to cool down.
You can't really disable the turbo; but the "softer" you coast home, the better chance you have for cooling the turbos. But it doesn't really matter, it doesn't hurt anything.
omgmike359.00
      04-06-2021, 11:17 AM   #35
spuntyb
spuntyb's Avatar
Drives: 2019 F90 Competition
Yes. My 2019 Comp does this every time I drive it, short or long trips. Like landing the space shuttle
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold)
2018 F80 ZCP TB|SS (sold)
2015 F30 335 AW|CR (sold)
2015 F31 MG|CR (sold)
2011 E90 JB|Oyster (sold)
Appreciate 2
zb26031055.50
      04-13-2022, 07:51 AM   #36
Rams01
Drives: 2020 F90 M5C
TTT can confirm: even after BMW replaced a cracked coolant expansion tank, my 2020 M5C will still sit there with fans on sometimes for 10 minutes after a spirited drive. Very interesting car; annoying it has that 165mph limiter
      04-13-2022, 10:10 AM   #37
omgmike
omgmike's Avatar
359
Drives: '22 M5C
I have less than 300 miles on a 2021 M5C. I went for a ride around several highways in Dallas for about 2 hours. Nothing crazy just highway speeds and then service road driving with stop lights closer to home. I monitor oil and water temperatures and no signs of a problem. I do not hear the fans running after I get home and turn the car off. Anyone with a 2021 hear fans running after car is shut off.
My '22 does it a lot. I originally thought it was a built-in turbo timer to keep the oil moving through the turbos to cool them down, but I guess it's the fan? My brother's old RX-7s (FDs) had aftermarket turbo-timers for exactly that reason, to keep the oil flowing for a few minutes, long enough to cool the turbos down.
      04-13-2022, 10:11 AM   #38
omgmike
omgmike's Avatar
359
Drives: '22 M5C
That's what I thought it was -- basically a built-in turbo timer. You used to have to install after market versions to cool your turbos, nice that it's factory these days.
      04-13-2022, 11:10 AM   #39
AHall
982
Do you live close to a highway? I have to drive for 15 minutes on service roads and neighborhood streets before getting home. So I am guessing my car is already cooled before I get home
      04-13-2022, 01:25 PM   #40
omgmike
omgmike's Avatar
359
Drives: '22 M5C
Sort of? US 290 is the main road out where I live, but it's not a freeway. It's about 5 mins from my house to 290.
      04-13-2022, 06:05 PM   #41
Resjudicata
That's what I thought it was — basically a built-in turbo timer. You used to have to install after market versions to cool your turbos, nice that it's factory these days.
Definitely. Comfort or eco will be cooler than sport or sport plus. But it's built in. Also the grille active open and close.
I wish I had a video after my track day showing how it opened, cooled and then closed, while I was out of the car.
      04-14-2022, 03:17 PM   #42
CFoote
Drives: '22 M5CS, '00 M5, '06 Z4M
2022 M5CS  [0.00]
2001 BMW 740i  [0.00]
2006 BMW M Roadster  [0.00]
2012 BMW X6 3.5i  [0.00]
2006 BMW 325xi  [0.00]
2017 BMW 540xi  [0.00]
2000 BMW M5  [0.00]
2001 BMW X5 4.4i  [0.00]
The engine runs hot. It's just cooling down...Hence why we have multiple batteries in the car.
Chris
'22 M5CS, '06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5, '01 740, 08 335xi, '17 540xi (yes they all are still with me)
      04-14-2022, 03:22 PM   #43
omgmike
omgmike's Avatar
359
Drives: '22 M5C
That would be super cool to see!
      04-14-2022, 06:05 PM   #44
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Clearly no one here watches racing. Lol. You should t let the car just sit idle to cool down. No different than just Letting the fans do their things. And as a few have stated it's not good for the engines to idle.
Ideally you should drive at stable low rpm higher speed for 5-10 min. This allows the engine to cool without high stress. If you ever watch a race particularly F1, you will see they all go for 1-2 laps for a cool down. They aren't driving slow mind you either. But they drive fast enough to get good air flow but don't stress the engine or spool the turbos too high. I typically come out of M1 and let the engine run in "eco" mode for the last bit of my drive home. This lets the engine run at lower RPMs and prevents spool up of the turbos uneccesarily. Don't get me wrong this won't 100% prevent the fans as they kick on based on coolant temp that we don't have access to monitoring.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
Namelss766.00
