01-07-2022, 09:51 AM | #1 |
Rep 11
Wrong Coolant Top Up - HELP!
Hi all,
I made a bit of a catastrophic (potentially) error today where I topped up my coolant with the "wrong" coolant. I saw a warning come on this morning about low coolant on the dash, so just used a VW coolant that was in the garage (from my Golf R). It wasn't until I'd done it that I realised that not all coolants were made equal. This is the coolant that I used: VW Original G13 https://www.amazon.co.uk/Volkswagen-...66881202&psc=1 I added about 300ml (1.5 cups) I reckon in total. Is this very bad or will it be ok? If bad, what should my next steps be? FYI it's a 2018 plate and out of warranty. Cheers Jono |
01-07-2022, 10:33 AM | #2 |
5287
Rep 10,682
I would not worry about 12 ounces of the wrong coolant among the roughly 372 ounce of coolant. VW G13 is the same spec as Zerex G05 and G05 is very close to BMW spec. Zerex G48 s the same spec as BMW, so if you have OCD and want to research further, compare Zerex G05 to G48. I think G48 is sort of a longer change interval version of G05.
01-09-2022, 12:18 AM | #3 |
769
Rep 1,684
What I know is if it has the same colour then you're fine.
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
01-25-2022, 11:07 AM | #4 |
1839
Rep 1,328
01-25-2022, 12:46 PM | #5 |
5287
Rep 10,682
The OP mixed some orange into his blue coolant. The question is how wrong that is. For the respective quantities, it is not an issue. And even if he filled the entire system with VW orange instead of BMW blue, I doubt there would be any consequences as long as he changed the coolant again within a few years or 50k miles.
12-29-2023, 12:25 PM | #7 |
5287
Rep 10,682
5% orange with 95% blue might give a little brown color. Technically corrosion protection could be minimally less. I would not worry, but if you are under warranty, BMW could hold the mixing against you. Any plans to change the coolant as preventative maintenance at some point? Can you sleep at night until then? If this is really going to make you anxious, then change it.
