08-15-2022, 09:57 PM | #46 |
5275
Rep 10,672
Was a cause specified? The belief had been that heat from the cats and/or turbos under the tank was causing the plastic to crack. Recently, there have been reports of dealer claims that a chemical reaction between aluminum heat exchangers and coolant damaged the tank and caused leaks.
Not sure which is the better theory. I replaced my tank preventatively. Maybe I will change the coolant preventatively. I think mine is original to my 2018 with 40k miles, but I bought as a CPO with 24k about 1.5 years ago and did not look at service records. |
08-16-2022, 03:49 PM | #47 |
2274
Rep 3,302
I hate this thread. Moderator please delete it.
rrrrrrrrrr......come on BMW come up with a proper METAL tank. Jack asses. Mike
08-16-2022, 05:42 PM | #48 |
259
Rep 294
Drives: 2019 BMW F90 M5 Competition
I'm on my second tank installed 2k miles ago..
Already starting to melt at the seams again. Getting 3rd one installed next week with the performance thermostat from turners see what happens.. :
LOYALTY AUTO GROUP
08-16-2022, 07:24 PM | #49 |
988
Rep 1,806
Coolant Leak
Why would anyone expect anything different? Replacing the failed tank with the same tank? What is the expectation other than another failed tank after x months? I am not sure the tank is the issue or the solution since someone else posted information whatever the cause is damaged the charge air coolers. There seems to be a compatibility issue with the coolant and other components such as tank and/or charge air coolers and who knows what else. Is it the blue coolant which caused BMW to change to the green coolant? Maybe others who have had tank failures also have damaged charge air coolers they just don't know about yet.
afo818259.00 |
08-16-2022, 08:17 PM | #50 |
553
Rep 547
Interesting, having owned my 18 M5 since August of 2018 (4 years) I have not encountered this problem. My M5 is a weekend only car with just over 10k miles. What concerns me is that you have 2k miles on a new coolant tank and you are in need of a 3rd coolant tank. Knock on wood I have no issues with my coolant tank.
afo818259.00 |
08-17-2022, 04:35 AM | #52 | |
988
Rep 1,806
08-18-2022, 07:54 AM | #54 |
5275
Rep 10,672
That is what I thought about the yellow level indicator making blue look green but I am no longer sure that is the case. The new BMW coolant definitely is green. I don’t know when it became available and began being installed from the factory. I’ll be partially changing it soon when I install the 90C thermostat so I will have some from my 2018 to sample.
08-18-2022, 10:42 AM | #55 | |
2274
Rep 3,302
I am ordering a new coolant tank today. Mike
08-18-2022, 02:01 PM | #56 |
Rep 37
Tried to check both coolant levels, main coolant cap was corroded on and took large channel locks to remove, was worried cap or neck would break, but got it off and lubed before replacing and cleaned. Small cap is frozen on and could not get off because of my worry about breaking, any thoughts on how to remove frozen small coolant cap without breaking?
08-18-2022, 02:19 PM | #57 | |
586
Rep 575
Drives: 2022 M5 CS & 2022 X5M
https://www.amazon.com/Oil-Filter-Wr...-1-spons&psc=1 |
08-18-2022, 02:58 PM | #58 |
988
Rep 1,806
I had an issue removing the main coolant tank. It appeared it may have not been installed straight when the BMW techs serviced the car during the annual oil change. No problem for the first 3/4 turn and then it got tight. I muscled through and now comes off and goes on without issue. It is a tight fit though.
08-18-2022, 03:00 PM | #59 |
988
Rep 1,806
Mike can you confirm the sensor cannot be removed? I have seen the coolant tank sensors for sale by BMW as if it can be changed. When I look at the sensor and tank on my car it does not appear to be serviceable, but maybe you can see something different once you have it off the car.
Aronis2274.00 |
08-18-2022, 03:07 PM | #60 |
5275
Rep 10,672
I have my old tank and it looks like the sensor is molded into the plastic tank. I have not fully explored whether the guts could be extracted from the molded plastic. Someone could measure the resistance of the sensor at a few points and try to compare to a removeable sensor for use in a custom tank. Probably BMW’s sensor is not unique to this car in terms of resistance, but I am not sure.
This link probably won’t work but realoem does not show a separate sensor. Looks like it is part of the tank. https://www.realoem.com/bmw/enUS/sho...diagId=17_1194 F10 M5 tank has separate sensor. Obviously tank levels differ. Maybe it is just an in/off switch and that is all you need for a custom tank. If low, a ground is broken and a warning light goes off. Or maybe it is much more complicated and a signal goes to the ECU to pull timing, limit power, etc. Worth researching that. Last edited by pbonsalb; 08-18-2022 at 03:15 PM.. |
08-18-2022, 03:11 PM | #61 |
Rep 37
Thanks, got it off with my motorcycle oil filter wrench, fluid is a little low, not at min. Corrosion on both filler necks, lubed with WD40 silicone and both are easy now.
starlord722.00 |
08-18-2022, 04:00 PM | #63 |
1739
Rep 1,663
Does anyone know if the 2020+ M550's share the same Big Coolant tank as the M5? I'm guessing yes. My car has been in twice now with "low coolant" and coolant smell inside garage. They keep telling me its "normal" which I know is bullshit. The next time I get a low coolant warning I'm going to insist they swap the tank. My 2020 M550 has 13,300 miles.
They "Pressure Test the System" and say that rules out any cracks. Which I still say is bullshit. I can SMELL the coolant so its leaking out somewhere.
2020 M550 / Dark Graphite / Napa Saddle Brown / DHP Pkg / Exec Pkg / Luxury Pkg / Parking Asst Pkg
08-18-2022, 04:22 PM | #64 | |
988
Rep 1,806
08-18-2022, 05:20 PM | #65 |
2274
Rep 3,302
A good sheet metal guy can fabricate a tank out of stainless that would fit in the space.
Mike
08-18-2022, 07:29 PM | #66 |
988
Rep 1,806
I contacted a custom tank manufacturer who indicated they can make a tank out of aluminum based on a link I sent him showing the coolant tank. The problem is the sensor integration.
