04-19-2024, 06:26 PM | #2 |
170
Rep 221
Yup, reputable exhaust shop will be able to get it done. They may have to add a a few inches of piping if that isn’t as long as the whole resonator. Again though, any decent exhaust shop should have zero issues.
04-19-2024, 06:30 PM | #3 |
5267
Rep 10,654
Would it work with some fabrication, sure. Would it be a direct bolt on, likely not. The centerline to centerline of the stock pipes as they exit the stock front resonator is about 5” and the centerline to centerline of the Magnaflo is about 5.75” so you would have to do a little pie cutting and welding. If you have a bandsaw and can weld stainless, you could do it. I would not crush bend. If you can’t weld, do you have a good shop? I think a lot of shops would charge enough to adapt that Magnaflo that you would not save much over the Dinan X pipe, and you can install that yourself if you can cut your exhaust yourself. If using a shop, it is an easy install for the shop — much much easier than adapting the Magnaflo.
04-19-2024, 06:55 PM | #4 | |
350
Rep 1,408
04-19-2024, 07:02 PM | #5 |
5267
Rep 10,654
Unless you have a good exhaust shop that charges reasonable prices. They do exist but aren’t always easy to find. Dinan’s X pipe starts at the end of the transmission and has several cut and welded sections for a reason, and it is just a merge rather than a true X. Just stay away from the shops that crush bend — fine for a work truck but you lose flow and that makes your exhaust lower performance.
Holset275.50 |
04-20-2024, 03:42 AM | #7 | |
276
Rep 655
04-20-2024, 07:00 AM | #8 |
5267
Rep 10,654
For performance, it makes no difference on the M5. The pulses are crossed in the manifolds before the turbos and the turbos then chew up the exhaust. Sound may still vary a little.
