11-08-2022, 08:25 PM | #133 |
4151
Rep 7,165
Drives: F90 M5 / F15 50i
Weight doesn't change based on brand. Motul is good stuff. Never heard of Esther
'07 Yamaha R1 (sold)
916_M5366.50 |
12-29-2022, 02:23 PM | #134 |
Rep 14
Drives: BMW F30 328i
I'll just chime in since I didn't see anyone note but here it is.
BP was awarded BMW oil contract in 2021 for USA, Canada, Mexico. With that said BMW oil is Castrol oil witch I belive is advertised as Castrol Edge 0w-30. Personally I use Liquid Moly 0w-30 along with a bottle of Liquid Moly Ceratec. I also suggest doing oil changes based on driving habits. If you track your car and use as a daily driver or you street race, drive hard everyday, you want to do oil changes more frequently. I do mine every 2500- 3000K If you never had your car over a 100mph well maybe you should buy a Prius sell the BMW! Have a nice Day! |
12-31-2022, 11:47 PM | #135 | |
4151
Rep 7,165
01-07-2023, 03:15 PM | #136 | |
1839
Rep 1,328
Different companies use different molecules. Redline and Motul prefer Esters, while Mobil uses PAO's. I haven't studied LiquiMoly enough yet to know for certain what their chemistry is. Shawn |
01-08-2023, 07:38 PM | #137 | |
4151
Rep 7,165
01-09-2023, 09:27 AM | #138 |
1839
Rep 1,328
The two things in your car that probably have the MOST amount of sophistication (cumulative) in their engineering are the oil, and the transmission fluid (trannie fluid more than oil, honestly).
The technology of making something spin at 10,000 rpm for 100,000 miles is VERY sophisticated. There are "tribologists" that probably have spent an entire lifetime on working on a specific additive package for a specific kind of oil. Shawn |
Maverik2594150.50 |
01-29-2023, 02:11 PM | #140 |
1839
Rep 1,328
I'm certain there is SOME group of situations where Redline 0W-40 is the perfect oil. But for daily driving of an M5? In the United States? Maybe Death Valley. Otherwise, probably best to stick real close to manufacturers recommended weight.
Shawn |
01-29-2023, 04:00 PM | #141 | |
1543
Rep 2,022
Also attached is the 2018 USA owners manual... im sure they totally changed the internals of the car without telling anyone. |
01-29-2023, 04:44 PM | #142 | |
1839
Rep 1,328
LL-01, ACEA? Given, there is a "close" to perfect oil for each engine, but only under different conditions. Death Valley? Mexico? Sure, 40 weight. But Virginia? More than 30 weight for this V8 may be too thick. Who knows? Not me now. But at least sticking close to the OEM recommendations is a pretty good bet. Thicker does not always equal better. Thinner does not always equal more wear and better emissions. It's just not that simple. Shawn |
micvite1543.00 |
01-29-2023, 05:07 PM | #143 | |
1543
Rep 2,022
But considering I did my own oil change shortly after the break in change done at the dealership on my old car... and after warming it up the oil was basically water coming out of the engine I personally don't feel comfortable running anything that thin with my driving style. |
shawnhayes1838.50 |
01-29-2023, 05:51 PM | #144 |
5287
Rep 10,685
If you want the oil BMW chose for CAFE purposes, use the thin oil option in the FE grade that BMW lists among in the range of weights and specs that work fine for these motors.
shawnhayes1838.50 |
01-29-2023, 05:57 PM | #145 | |
1839
Rep 1,328
And on the temperature when I track? Never EVER goes above 250. Never ever. My old GT-R, sure. Cooling for that car was inadequate. BMW has gotten it right. I've never been able to get any of the temps over normal driving around temps. Some people have. No idea why, other than I don't drive in July much anymore. One of my crew (traveling buddies who meet up at various tracks) nearly died at a NASA event at VIR in his GT3 with no air conditioning. We just don't do July much anywhere (northern tracks we still do, but Summit Point in August last year was nearly unbearable) And on the last part, there's NO WAY you can tell a hot 30 weight vs. a hot 40 weight by the way it runs out of the drain plug. Unless you're sitting there with a stopwatch and you measure it. The Mach-1 eyeball ain't that good. It just isn't. At zero deg F, maybe. But not hot, not even at zero deg F outside temp. If we're just gonna eyeball it, then all the science goes right out the window. Shawn |
micvite1543.00 |
01-29-2023, 06:03 PM | #146 | |
1543
Rep 2,022
To a certain degree you're right about the science simply because I can't guarantee it was even the same exact temp, or even close for that matter or even if it was I can't guarantee I didn't do something a bit different, but just feeling the hot oil on my hand and seeing the way it drips off you can definitely tell there's a difference. |
01-29-2023, 06:13 PM | #147 | |
1839
Rep 1,328
The only way to tell for sure is to check multiple oil analyses over multiple changes. Been there, done that, on a car with absolutely shitty cooling. After THOUSANDS of dollars of testing (nope, not kidding), the only thing I was able to prove was this oil: https://renewablelube.com/products/b...shp-0w20-pcmo# Was A LITTLE better than Mobil-1 0W-40 for a tracked GT-R. But just "a little". After all that, I came to the conclusion that "OEM is nearly as good as any boutique high cost oil that you can come up with on a car that is properly designed". Shawn |
01-29-2023, 06:20 PM | #148 | |
1543
Rep 2,022
In terms of the m5, I'd say it was a cooling issue in the end, most likely due to possible bent fins in the rad(lots of rocks get kicked up on that track), and also the kind of track, no huge straightaway to really cool things off, lots of short spurts in short succession. |
shawnhayes1838.50 |
02-05-2023, 05:10 AM | #149 | |
136
Rep 254
02-05-2023, 05:32 AM | #150 |
1543
Rep 2,022
02-05-2023, 08:56 AM | #151 |
989
Rep 1,807
02-05-2023, 11:18 AM | #152 | |
1839
Rep 1,328
A 0W-30 kinematic viscosity at operating temperature is 12.18 mm2/sec. A 5W-40 kinematic viscosity at operating temperature is 12.8 mm2/sec. These are very small differences. Shawn |
02-05-2023, 12:49 PM | #153 |
136
Rep 254
Funny you were being sarcastic but I actually did hear in fact that some changes really were made to the lci without noting it. The cylinder coating mentioned by the poster below is one to name a few, I just can’t remember if there was anything else (even physical changes wouldn’t surprise me). The zf8 for example was changed from zf75 to a stronger zf76 yet they never explicitly mentioned it.
02-05-2023, 12:50 PM | #154 |
136
Rep 254
