07-15-2020, 11:59 AM | #89 |
101
Rep 80
Just did this install with a Mirrortap. Took probably 15 minutes with only taking the big cover off. To get the Mirrortap into the harness I used a pair of curved hemostats (curved thin pliers would also work) to maneuver the pins into place, as I don't know how I would do that with my fingers without removing the other trim pieces. Putting the big cover back on was a little tricky but once it's lined up properly it snaps into place with a moderate amount of force.
07-15-2020, 12:19 PM | #90 | |
Hide! My wife's coming!
814
Rep 2,816
Gotta be delicate removing the main cover. On my G12, I broke the clips which are attached to the windshield. Only way to fix it is with a new windshield. Horrible design. https://f90.bimmerpost.com/forums/sh....php?t=1556366
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
07-27-2020, 03:11 PM | #91 | |
11
Rep 51
P.S. Thanks to the person that recommended using a credit card to pry apart covers 2 and 3, came in handy for sure. |
09-02-2020, 02:56 PM | #92 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
I have tried 20 plus times no luck. I get no power at all. is there a fuse somewhere? But then I think fuse is fine. When u unplug rear view garage lights don't show up but when I plug it in they are fine so assuming not a fuse issue.
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
01-24-2021, 08:11 AM | #93 |
26
Rep 32
Great writeup
Did this yesterday. Just took top collar off and used a long nose to jam them in. Note you need to push in so no metal is showing. Thanks much!
01-27-2021, 06:45 AM | #94 |
580
Rep 650
I've got a Radenso Pro M I would like to hardwire, but I was thinking I would do a fusetap. Are there fuse panels in the side of the dash?
02-09-2021, 08:56 PM | #95 |
Rep 6
Drives: BMW M5 Competition LCI
Thanks for the DIY post. Answers most questions I had. Now I’ll wait until warms up a bit (Iowa Winter) in the garage before I give it a go. Will be wiring in a V1 Gen 2.
02-23-2021, 02:52 PM | #96 |
45
Rep 61
So Ive been using the mirror tap for over a year now and all of a sudden it just stopped working for me. I got a new cable and it still doesnt work.
the radar works if I plug it into the Cigarette adaptor so i know the issue is not the radar. the garage buttons also works so im not sure what else to do to troubleshoot. Anyone have this issue ? thanks |
02-23-2021, 06:24 PM | #97 | |
1105
Rep 1,607
GT
02-23-2021, 06:37 PM | #98 | |
4092
Rep 5,239
06-15-2021, 11:27 AM | #100 |
25
Rep 79
Is anything different about this procedure with a 2021 M5, especially with Driving Assistant Professional?
I ask because I have had zero luck in getting the larger cover off, following the instructions here, watching some videos on YouTube, etc. I've applied a pretty significant amount of force and it just isn't budging, and I really don't want to break anything (especially the clips that someone mentioned are built into the windshield itself). |
07-17-2021, 05:46 PM | #101 |
323
Rep 347
Thanks for the instructions and all the data points here. I was able to get this done with my R7 and blendmount wires.
The first cover is a effing B. I struggled but finally got it off and chipped one of the clips in the process, but thankfully the cover still went back on and stayed with no movement or vibrations when driving. My wiring was also different than OP but figured that out after the R7 didn’t power on and had an autowiper error. All good now. Thanks for providing the wiring documents. I have mine mounted right under the dot matrix and have no issues with the radar working. |
10-29-2021, 11:11 AM | #102 |
199
Rep 572
I did this in my 2018 and it worked out fine. But in my 2022 LCI, that top cover just does not want to budge. So I decided to wire to the fuse box in the passenger side foot well. Maybe a little more effort, but I really didn't want to break that cover. There is another thread about the fuse method:
https://f90.bimmerpost.com/forums/sh....php?t=1596640 |
06-14-2022, 08:26 PM | #103 |
33
Rep 30
Drives: 2021 BMW M5 Competition
Just did this with a V1G2 in my '21 M5C and worked perfectly with mirror tap. I was able to remove just the large plastic housing per the OP and used needle nose pliers to tap into the connector. Was a bit awkward to get the taps aligned and probably easier removing all the trim pieces, but was able to do the install in ~25 min total.
06-19-2022, 08:42 PM | #104 |
176
Rep 152
Drives: '22 Dark Graphite M5C
I’ve had detectors hard wired in vehicles for the past decade. This post made the F90 install so easy and I didn’t have to spend all night trying to get it to work! Thanks a million!
AGS501.50 |
09-12-2022, 11:49 AM | #105 |
312
Rep 206
Hey brother, was the wires you tapped into the same as the ones mentioned on this write up? I am going to do the installation sometime this week and I wasn't sure if the wires and color code changed with the LCI.
09-12-2022, 12:47 PM | #106 |
329
Rep 483
I'm not the OP, but I did my LCI and it was the same.
DarkishM5C311.50 |
09-12-2022, 12:48 PM | #107 | |
4159
Rep 3,706
Drives: 2022 M5C
Not a BMW guy...but certainly an M5 guy.
DarkishM5C311.50 |
09-12-2022, 12:49 PM | #108 |
312
Rep 206
Dethsupp0rt ResIpsaLoquitur thank you guys for confirming.
ResIpsaLoquitur4158.50 |
09-12-2022, 04:47 PM | #109 |
312
Rep 206
AGS thanks for the write up, it really made it easy installing the mirror tap. For removing the trim around the mirror, this video helped. https://youtu.be/jTQFVoRIkuE
AGS501.50 |
09-12-2022, 05:30 PM | #110 | |
329
Rep 483
