BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Low coolant warnings
      02-20-2023, 02:33 PM   #67
carseatsm5
Drives: 2020 M5
2020 with about 10K miles. Checked coolant (no warning light) and found it was low with splatter around cap and tank. Made appointment to go into dealer tomorrow.
This is what we’re talking about right? This isn’t just a normal spill from it being refilled (just had my annual maintenance done like a month ago)?
      02-20-2023, 02:49 PM   #68
pbonsalb
5287
Yes, that one has not been sealing well. Could be the cap or maybe the tank is cracking. If enough coolant drips, it can get on the injectors, coils and wiring underneath and cause issues over time. Better to check periodically and act as soon as you see the white residue.
      02-22-2023, 11:24 AM   #69
carseatsm5
Drives: 2020 M5
SA updated me this morning. Confirmed leak from the expansion tank. Replacement part arrives tomorrow.
Glad for the forum because I never even had a low coolant warning, just checked out of precaution.
Appreciate 2
      02-22-2023, 11:01 PM   #70
Ropes
Ropes's Avatar
Drives: 2020 M4 CS
You might want to consider changing your spark plugs and coils too. The coolant leak from an expansion will get all over them and can cause issues.
      02-23-2023, 09:33 AM   #71
carseatsm5
Drives: 2020 M5
Good idea. Will flag.
      02-25-2023, 03:18 PM   #72
carseatsm5
Drives: 2020 M5
There is a service bulletin for this issue, updated in September.
https://www.tsbsearch.com/BMW/SI-B17-02-22/888
      03-14-2023, 06:36 PM   #73
dcohen13
Drives: M5 Comp
Funny, my light came on and I have the same residue around mine. Texted my buddy at Sterling BMW and he said: "Looks like expansion tank is leaking. I see that a lot, bring it in, covered under warranty."
Looks like this is very common! I am at 29,XXX miles. 2019 M5 Comp.
      03-14-2023, 07:08 PM   #74
ResIpsaLoquitur
ResIpsaLoquitur's Avatar
4159
Drives: 2022 M5C
Extremely common! Probably the most common thing that fails on these cars. It’s always the number one answer when someone newer gets on this forum and asks, “I am looking at a preowned M5, what should I be looking out for?”
Not a BMW guy...but certainly an M5 guy.
Appreciate 2
      03-15-2023, 09:09 AM   #75
dcohen13
Drives: M5 Comp
thank you!!
      03-15-2023, 12:15 PM   #76
ResIpsaLoquitur
4159
Drives: 2022 M5C
thank you!!
You’re welcome!
      03-15-2023, 05:14 PM   #77
dcohen13
Drives: M5 Comp
Took the car in, grabbed a loaner, and the dealer finished in 2 hours. Was an easy fix.
      03-15-2023, 07:20 PM   #78
ResIpsaLoquitur
4159
Drives: 2022 M5C
Awesome! Glad to hear it.
dcohen13682.00
      03-30-2023, 09:39 PM   #79
hookson
hookson's Avatar
91
Drives: M4 2015, M5 2019
If your tank fails that’s how your injectors will most likely look like.
      04-05-2023, 09:54 AM   #80
LASpartan
104
Drives: '21 BMW M5
I got a low coolant warning yesterday right after I noticed a large puddle under my car. I am assuming they are connected. Brought the car right into the dealer and they gave me a 430i loaner (I hate that car--just so ugly and you realize how well the M5 drives when you drive the 430i).
      04-05-2023, 10:56 AM   #81
LASpartan
104
Drives: '21 BMW M5
Dealership called me and said something hit the actual cooling unit and it is not covered under warranty and it costs $2,300. Can anyone advise if I am being screwed?
It is the Right Side Auxiliary Low Temperature Cooler that has a puncture and is leaking.
      04-05-2023, 11:12 AM   #82
pbonsalb
5287
Dealership will usually be the highest price. You could probably buy a used one on eBay for $250, buy a couple of gallons of G12 and distilled water for $50 and change it in 3 hours, but I have not actually done the job so I am guesstimating. Independent shop would usually be less than the dealer.
LASpartan104.00
      04-05-2023, 11:16 AM   #83
LASpartan
104
Drives: '21 BMW M5
I need my car and don't have the ability to have it towed, etc. I am just paying it and moving on. I also can't find anything regarding this being a warranty claim so it's just unfortunate.
      04-05-2023, 06:46 PM   #84
AHall
989
Drives: 1993 Nissan 240sx
For $2,300 there must be something more than replacing that tank. Was there collateral damage? What could have possibly hit the tank under the hood. I assume this is the passenger side tank.
      04-05-2023, 08:45 PM   #85
BobsM3Coupe
BobsM3Coupe's Avatar
Drives: X5MC
I believe he means the radiator on that side got struck by something. They are not cheap.
AHall989.00
      04-05-2023, 08:53 PM   #86
pbonsalb
5287
They are relatively cheap. But dealers and dealer labor make anything expensive.
https://parts.bmwofsouthatlanta.com/...or-17118620207
      04-07-2023, 05:42 PM   #87
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Definitely not warranty if it got hit. More like insurance. If you wanted to go that route.
But too late obviously.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      10-31-2023, 09:05 PM   #88
The5rivers
323
Drives: 21 M5C, 22 X3MC, 24 X7 40i
2021 M5C, 13.7K miles. I had the "engine coolant level low" error message pop up after a cold start tonight for about 4 seconds that went away on its own. Temp outside was 34 degrees. I drove away and the error message didn't come back. Stopped and started a few more times while running errands and still nothing.
I'm going to check out the fluid level tomorrow and see if it's actually low but made an appointment with my dealer on Monday to check for a leak and going to show them the TSB and probably just push to get it replaced under warranty.
