05-09-2019, 02:43 PM | #45 | |
500
Rep 1,313
Best,
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
05-09-2019, 04:09 PM | #46 |
19791
Rep 10,247
Ok let me see what I can do, I am not driving it today.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
05-09-2019, 09:10 PM | #47 | |
13112
Rep 18,786
I got all the data on F90 M5 wheel setup, maybe I can help you.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
05-09-2019, 09:21 PM | #48 |
500
Rep 1,313
2019 M5 Comp. Ideally would like to run something less than 10mm spacers in the back. 13mm or so in the front. Trying to figure out rear wheel options on the spacers. All the pics I've seen of 10mm or greater seem to suggest the rear wheels stick out past the rear fenders.
05-09-2019, 10:22 PM | #49 | |
13112
Rep 18,786
05-10-2019, 06:59 AM | #50 |
500
Rep 1,313
05-10-2019, 08:18 AM | #51 | |
13112
Rep 18,786
Only 3mm then jump to 11mm. Nothing in between.
05-10-2019, 09:23 AM | #52 |
500
Rep 1,313
So what are all the sizes of spacers available? 3mm, 11mm and then what beyond that (may want something larger than 11mm on the front).
05-10-2019, 09:29 AM | #53 | |
19791
Rep 10,247
Found these too:
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 05-10-2019 at 09:45 AM.. |
05-10-2019, 09:54 AM | #54 | |
500
Rep 1,313
Do you think I'd have similar clearance with the same 15/12 setup you are running?
05-10-2019, 09:55 AM | #55 | |
19791
Rep 10,247
05-10-2019, 10:21 AM | #57 |
19791
Rep 10,247
05-10-2019, 10:46 AM | #58 |
13112
Rep 18,786
3, 11, 12, 13, 15, 18, 20, 22.5, 25, 30.
05-10-2019, 04:46 PM | #60 |
500
Rep 1,313
r33_RGSport13112.00 |
05-13-2019, 09:07 PM | #61 | |
500
Rep 1,313
https://ind-distribution.com/collect...ort-spring-set If so, how much of an additional drop do you think I'd see on my M5 Comp? Maybe the rear wouldn't drop much, but the front might drop more?
05-14-2019, 08:59 AM | #62 | |
19791
Rep 10,247
Whatever the M5 CE drops the car farther than stock is what you need to see. I think its 10mm or close to that. So in my case since my fronts dropped about 30mm you would see a 20mm drop on the CE vs the stock CE set up. And because my rears dropped 15mm with the F90 springs you would see only a 5mm drop further. What you need to confirm is the stock CE drop vs the non CE stock drop. But its around 10mm from what I remember. And no matter what the new springs eliminate the CE drop in the whole so your car would look like mine.
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 05-14-2019 at 09:26 AM.. |
05-14-2019, 09:38 AM | #63 | |
500
Rep 1,313
05-14-2019, 09:47 AM | #64 | |
500
Rep 1,313
05-14-2019, 09:55 AM | #65 | ||
13112
Rep 18,786
Both cars will have the same stance after using H&R spring. The difference between CP anf non, mainly are the spring rate and damper valving (or just programming). Overall weight of both cars are still the same.
05-14-2019, 10:25 AM | #66 |
500
Rep 1,313
So is spring rate and damper valving (or programming) unaffected by the change in springs? What I don't want to happen is change some other characteristic/performance of the car (other than stance) by switching springs.
B18c jdmgsr71.00 |
