BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Winter tires
      09-10-2018, 05:12 PM   #45
bengals9
Drives: M5
Guess I'll never understand the load #'s. For instance, my summer 19" have load #'s as follows: 105 in front and 107 in rear. The square setup is 102 all around. I was told by Michelin not to get the Pilot Sport A/S 3+ because they are 101 front and 103 rear for this car. Now BMW says 102 is ok. I just don't get it. Any thoughts appreciated.
      09-10-2018, 07:28 PM   #46
Rjduff
Rjduff's Avatar
Drives: 2018 M5
Can anybody tell us about the Alpin 5 tire that comes with this setup?
      09-16-2018, 09:55 AM   #47
jensputzier
Germany
99
Drives: 2018 F90 M5
I will order a set of standard 20" rims and add Michelin Alpin 4
front: 275/35 R20 102W
rear: 285/35 R20 104W
HAZET Stahlwille Knipex German tools shipped worldwide.
http://www.jensputzier.com
Last edited by jensputzier; 09-16-2018 at 02:56 PM.. Reason: changed from PA 5 to 4, typo.
      09-16-2018, 10:38 AM   #48
kdeleon
94
Drives: M5
Originally Posted by jensputzier View Post
I will order a set of standard 20" rims and add Michelin Alpin 5
Will they make Alpin 5's in that size? Last I checked Michelin's site, those sizes weren't included. I also went standard size 20" wheels that are being custom made. But I thought I was only limited to the Pirellis. At least this will give another option in the future.
      09-16-2018, 02:55 PM   #49
jensputzier
Germany
99
Drives: 2018 F90 M5
Sorry, my bad, it's still the 4. I chose those as the have a W speed rating which is important for me.
      09-22-2018, 12:27 PM   #50
stbm5
261
Drives: 2018 M5 DG
i'm being told that the only 20 inch tires that fit staggered set up winter wheels with correct load ratings are the pirelli sottozero series II. I've had these wheels previously on M4 and thought they were great. told michelin does not have an alpine front tire with correct specs.
      09-23-2018, 09:03 AM   #51
remmib
remmib's Avatar
Norway
1571
Drives: 2013 F10 520d M-Sport
Here in Norway Michelin lists the pilot alpin 4 in 275/35/20 102W and 285/35/20 104W, so they do exist.
      09-23-2018, 10:32 AM   #52
stbm5
261
Drives: 2018 M5 DG
i looked and couldn't find them, anyone know a USA source?
      09-23-2018, 09:43 PM   #53
ST3
ST3's Avatar
340
Drives: F90 M5
Thank you! Does anyone have a better contact with Tire Rack that we could reach out to ? Would be nice to know if it is delayed or simply not going to happen in U.S.
      09-24-2018, 02:38 PM   #54
neohh
168
Drives: F90 M5
I am wondering if 245/40/20 and 265/40/20 would works on OEM 20' wheels. Thoughts?
      09-25-2018, 10:39 AM   #55
Ragazzi-07
Ragazzi-07's Avatar
247
Drives: 2018 M5
probably just get the Pirelli's in OEM fitment
https://m.tirerack.com/tires/tires.j...5&autoModClar=
      09-25-2018, 02:25 PM   #56
neohh
168
Drives: F90 M5
Yes, that's what simply tire suggested.
      09-25-2018, 07:24 PM   #57
stbm5
261
Drives: 2018 M5 DG
the pirellis are good. if its warm out you will feel them squirm a bit due to heavy siping but when its sub 40 deg out, you'll be glad you have them.
      09-26-2018, 07:36 PM   #58
doug_999
doug_999's Avatar
2545
Drives: 2011 1M/2021 992/2023 X3
Hi everyone... have two friends (yea, only two ) One got a M550 this summer and one got a M5.
1. As noted, the wheels are not compatible. The bolt pattern is fine, it is the offset.
2. BMW recommends the square setup in 19" wheels for the M5 because
a) More tire to absorb those lovely potholes with the 19s"
b) skinnier tires do better in the winter.
3. As noted, BMW sells the complete set (since they are all the same tire/wheel, they are sold individually). This is nice because
a) it is a real BMW wheel not a knock off
b) comes with everything you need - TPMS, balanced - heck, even the BMW center cap
c) is covered by your warranty and your tire and wheel warranty if you purchased that
Alas, it is more money to "do it yourself" and buy the wheels and then add your preferred snow tire - plus TPMS, plus mounting, plus balancing...
and I drove on 20" all seasons here in Chicago (swapped out my summer run flats on my 650GC). I had the Continental DWS tires. There were "ok" - the scary part is that occasionally the car would decide it was time to just sort of track towards the curb and you would just pray that it would correct - which it did. But let me tell you, I missed having 19" or even 18" wheels in the snow. 20" wheels just kind of suck - for a lot of reasons. But they sure do look cool
HTH
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      09-26-2018, 08:58 PM   #59
bengals9
Drives: M5
HTH
Thanks
Only 1 problem
Anyone know which dealer in NY area even had any inventory?
I can't find them
      10-01-2018, 11:12 PM   #60
kdeleon
94
Drives: M5
FYI. For those looking for the 20" snow tires in the OEM fit, it seems like Tire Rack is getting the Pirellis in stock sooner than they thought. Seems like they are back in stock tomorrow.
      10-02-2018, 09:05 AM   #61
Ragazzi-07
Ragazzi-07's Avatar
247
Drives: 2018 M5
Keep us posted on other options besides the Pirelli Sottozero serie ii
      10-08-2018, 10:28 AM   #62
ksoze
ksoze's Avatar
Drives: 2018 M550iX
Are you sure the winter wheel/tire set is covered by same policy? I was told the coverage is only for the OEM wheel/tires on the car when bought, not a winter setup.
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
      10-08-2018, 12:23 PM   #63
ST3
ST3's Avatar
340
Drives: F90 M5
I can check on my contract. The dealer on multiple occasions (and in writing) stated coverage was for the original wheels as well as the winter set I ordered.
      10-08-2018, 01:29 PM   #64
ksoze
ksoze's Avatar
Drives: 2018 M550iX
My contract says OEM wheel and tires on car when new are covered as well as new tires mounted on the same wheels. Just called and confirmed it DOES cover the winter set as long as they are a standard BMW offering.
      10-13-2018, 11:41 AM   #65
Stav
Drives: F90 M5
Does anybody know if there are other options for the 20" wheels beyond summer tires and the winter Pirellis tire rack has? I have the oem summer Pirellis now and I want to replace them - just to see if all the vibration I am getting is because of them - but with winter low temperatures coming I don't want to go with the summer Michelin.
We only get snow/ice here in TN maybe once a year but temps do go down to under freezing morning and nights from December to March or so.
      10-13-2018, 04:32 PM   #66
Materhead66
Materhead66's Avatar
Drives: M5
I have been searching and cannot find an all season performance tire that meets the complete specs. The load factor on the front / rear on the summer tires is 102 / 104. I can find the Michelin 3S+ only in a 100 in the rear size.
