BMW M5 F90 (2018+) General Forums Cosmetic Modifications    Fshngry m5c + cs trunk spoiler
      11-24-2021, 05:37 PM   #23
trev230
trev230's Avatar
352
Drives: 2022 M5C
Originally Posted by eman4517 View Post
I just installed mine myself last week and I'm very happy with the results!
The OEM Competition black rear lip spoiler itself was relatively easy to remove. I did it in about 15 minutes with some fishing line and a heat gun, however, the residual 3M tape was A BEAR to get off! That part I did VERY CAREFULLY manually in very small sections at a time with GOO-Off and isopropyl alcohol and it took me about 2 hours!
I had IND pre-install the 3M tape underneath the spoiler and also checked the pre-applied ceramic box (my car has full ceramic) so installing the CS CF spoiler on the car was a breeze. Because it's OEM, it aligned with the trunk's lines very well and I installed the CS spoiler (after the trunk was prepped) in about 10 minutes. I just positioned it where I wanted it, then made a blue painter's tape template around it, pulled about an inch or 2 of the red 3M tape plastic back (on the bottom of each end of the spoiler), pressed hard for about 30 seconds, repeating with each several inch segment, until the end.
Here's some pics... (Incidentally, we just bought back our X1 (next to her) off-lease, that was a no-brainer with car prices the way they are...that was a steal!!)
Looks great. What you removed from the OEM spoiler is called Betalink. It’s BMW’s adhesive they recommend and use on all OEM spoiler parts. Just a tip in the future heat it up a little with a heat gun and take your finger and “rub” it in the direction of the glue strip and it will come off much easier and quicker. I’ve done several in around 2.0-30 minutes this way. I’ve never reinstalled a spoiler with the betalink though…Always used the higher quality trim level 3m adhesive and it’s never failed if you apply it correctly etc.. Sounds like you did a great job. Just wanted to let you know you can remove that betalink another way next time to maybe save you some time. That is some nasty stuff lol.
Appreciate 2
eman45171748.50
Jamesmick131.00
      11-24-2021, 09:05 PM   #24
FSHNGRY
FSHNGRY's Avatar
Drives: INDIVIDUAL F90 M5C LCI
Originally Posted by ashmostro View Post
Looks awesome on your car FSHNGRY! You may recall I was debating both spoilers for my Tanzanite LCI car, and actually bought both spoilers to visually assess. I ended up preferring the PRO as I think for more muted colors like mine. The added over-the-topness is needed. But it was a very tight race, you can’t go wrong with the CS.
Clean car!
-Ash
Congrats! The joys of being able to order both options of a part available before choosing which one is the right fit!
Drop some pics! I'm curious how it looks on that awesome exterior color choice.
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED
GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED
GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG |
IG: @FSHNGRY
      11-24-2021, 09:06 PM   #25
ashmostro
Drives: 2020 M4cs | 2022 M550i
Will do! Out of town right now for Thanksgiving, so will do in a few days!
      11-25-2021, 09:08 AM   #26
eman4517
Enthusiast
eman4517's Avatar
Drives: '24 G83 M4C xDrive
Thanks for the pointers trev230! Yes, I actually tried heating and rolling the betalink but it was too thick and it went back into place and wasn't budging much in larger sections. I think I wasn't close enough to the trunk surface with the fishing line when I separated the OEM Competition spoiler from the betalink, so it might have been too thick to roll by that method (hence the blisters on the thumbs!). I was a little nervous getting that close to the paint or even trying a rubber adhesive removing wheel, so I just ended up rolling it back towards the edges in small balls, then thinning it out with the 2 paint-safe solvents as I continued. First time installing. cheers!
'24 G83 M4 Comp xDrive SG/Black, '23 U11 X1 PB/Oyster
Gone but not forgotten:'22 G82 M4Comp xDrive, '21 F90 M5 Comp,'19 Porsche 911 C4S, 15 Audi RS5, etc..
      11-28-2021, 11:28 AM   #27
ashmostro
For anyone reading this in the future, do yourself a solid and go out and buy some Mother’s R3 race rubber remover. it’s intended purpose is to get molten racing tire streaks off of paintwork, but since beta link (and 3M tape) are petroleum based, it works wonders on them. I use the Goo Gone first, to soften and absorb into the tape or Betalink, and the R3 gets rid of ALL the residue that remains, especially that stubborn leftover hazy layer that you can’t scrub off with Goo gone alone.
Appreciate 4
m5 guy1742.50
FSHNGRY2389.50
eman45171748.50
Jamesmick131.00
      11-29-2021, 09:25 PM   #28
myounz
myounz's Avatar
162
Drives: M3 Competition
Beautiful!
      12-13-2021, 05:51 PM   #29
Silverx88x
Drives: 2019 M5 Competition
looks great and beautiful car!
      12-27-2021, 11:39 AM   #30
eric97hoh
Drives: 2020 bmw m5
i was about to order the m5 cs spoiler but its 1600 on find instead of 600 just shot up 1 grand in price so I got the m performance pro spoiler ;(
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel
      12-27-2021, 04:40 PM   #31
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
That's nuts … just paid $590 in early November for the CS spoiler. That's a crazy increase in price.
BMW Parts pros has it for $625.00.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
FSHNGRY2389.50
      01-02-2022, 05:48 AM   #32
eric97hoh
Drives: 2020 bmw m5
Wow I wish I saw this earlier my bmw m performance pro spoiler arriving January fourth with fed ex wonder if I could ship it back and get the cs one let me wait and see wonder how it looks
      02-23-2022, 10:50 PM   #33
TROYJEUP
Drives: All of them
Call me crazy but I was planning to take my spoiler off the cs and put the m pro part on. I was either going to install the cs spoiler on my wife's car or sell it but then I just got a 3d design spoiler for the Singapore car so who knows. 😂 I thought the m pro was a more aggressive look Than the m5cs spec but I've never seen it in person . I love the car by the way. One of the best out there. The color is similar to my 22 gts coupe in Chalk. Way better than the cs brands grey I was stuck with.
For what it's worth it appears my cs spoiler was taped on I think I could have pulled it off pretty easily.
Over 30 M-cars
      02-24-2022, 05:31 AM   #34
Boosted_8
450
Drives: M550i
CS spoiler squad assemble!
FSHNGRY2389.50
      02-21-2024, 03:05 PM   #35
kepatel12
kepatel12's Avatar
Drives: 2019 BMW M5 Competition
Does anyone have a picture of the OEM CS spoiler on a pre lci car? It looks great on the LCI cars, but curious to see how it would look with the pre lci tail lights.
