BMW M5 F90 (2018+) General Forums Cosmetic Modifications    Wheel spacers
      06-19-2021, 01:51 AM   #23
FSHNGRY
FSHNGRY's Avatar
Drives: INDIVIDUAL F90 M5C LCI
KW H.A.S. Kit
15MM Macht Schnell Spacers (front)
12MM Future Classic Spacers (rear)
285/35/20 (Front) Michelins
295/35/20 (Rear) Michelins
Spacers and KW's from IND
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED
GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED
GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG |
IG: @FSHNGRY
Appreciate 3
Jamesmick131.00
SGMM5115.50
selbyp93163.50
      07-04-2021, 10:26 AM   #24
TimWM5Comp
Drives: 2021 M5 Comp
Do the spacers affect anything on the handling of the car?
      11-01-2021, 03:43 PM   #25
naz162uk
United Kingdom
Drives: Bmw m5
Originally Posted by samj2k View Post
Originally Posted by aerospace100 View Post
Hi Guys,
M5 F90 with 20" wheels.
Which thickness of spacers should I use on front and back?
Links to purchase would be much appreciated.
15mm Front and 12mm rear is the perfect combination.
I did this and have rubbing on back with 3 passengers in rear
      11-01-2021, 10:00 PM   #26
Ptoscano911
Drives: F90 M5
Hi Guys,
Rubbing w 3 adult passenger in rear or kids
      11-03-2021, 08:28 AM   #27
naz162uk
United Kingdom
Drives: Bmw m5
Hi Guys,
3 teenagers / adults 😀
      11-03-2021, 04:02 PM   #28
Ptoscano911
Drives: F90 M5
Hi Guys,
Are you lowered ?
      11-04-2021, 09:11 AM   #29
naz162uk
United Kingdom
Drives: Bmw m5
Hi Guys,
Are you lowered ?
No sir
      11-16-2021, 08:58 PM   #30
Jambo1
Drives: 2022 M5C /// 2023 XDrive40i
  [0.00]
This is interesting and thanks for letting us know about the rubbing. I’m not lowered (yet) and was going to do 15F/12R until you mentioned rubbing in the rear.
Do you think going 2-3mm thinner in rear would prevent any rubbing?
      11-16-2021, 09:19 PM   #31
Ptoscano911
Drives: F90 M5
Same thing. I don't want a to run. Maybe 10mm rear
      11-24-2021, 09:14 PM   #32
Holset
Sweden
279
Drives: F90 M5 Comp LCI
Hi Guys,
Do you have the EU plastic wheel arches on your car?
Removing them might get you some more clearance.
      03-03-2024, 10:18 PM   #33
djnuge
Drives: b7
Great info.
      03-07-2024, 12:00 PM   #34
djnuge
Drives: b7
Originally Posted by FSHNGRY View Post
KW H.A.S. Kit
Attachment 2630601
Attachment 2630602
Attachment 2630603
I like the thicker/taller tire set up. No rubbing with the 15/12 set up?
      03-11-2024, 12:41 PM   #35
windtendo
windtendo's Avatar
1725
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
You won't rub with a lowered 15/12 setup. I'm lowered with 17/11 Dinan spacers and no rubbing issues.
IG @windtendo_m5
      04-09-2024, 01:53 PM   #36
djnuge
Drives: b7
You have the OEM wheel set up?
      04-30-2024, 12:57 PM   #37
M5_1of400
M5_1of400's Avatar
Drives: 2018 M5 / 2011 X5 35d
KW H.A.S. Kit
Attachment 2630601
Attachment 2630602
Attachment 2630603
I have the exact same setup (not lowered) 15mm front / 12mm rear with 295s on the back and 285 on the front but tires stick out a tiny bit, not fully flushed with the fenders. Wonder why?
      04-30-2024, 09:32 PM   #38
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Since he’s lowered, it is probable he had an alignment performed and tucked the wheels slightly w/ negative camber.
The owner’s a friend and he’ll more than likely respond to confirm.
I’m on 21” wheels, KW V4’s and 295-285 Michelin PS4S and had an alignment performed after the coilovers settled .. I was able to tuck slightly inside the fender for a more flush look.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
FSHNGRY2389.50
      05-01-2024, 06:58 PM   #39
M5_1of400
M5_1of400's Avatar
Ahh that makes sense, maybe I need an alignment as well, but honestly I kinda like that they stick out a bit, it looks super aggressive but mostly concerned if I hit a big bump and possibly rubbing right on the edge and destroying my fenders and tires
      05-04-2024, 08:23 PM   #40
FSHNGRY
FSHNGRY's Avatar
What he said ^
IG: @FSHNGRY
      05-08-2024, 01:38 PM   #41
windtendo
windtendo's Avatar
1725
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
correct, OEM wheels and tires
IG @windtendo_m5
